The solution of gasoline in lpg vehicles
08.05.2020 15:02 # 1
sercinho
While I was searching for friends about the gas gauge problem in my car, I saw an application like this, I hope I couldn't load it fully, but let me give you a direct link.
http://www.2a-lpg.com/duyurular/psa%20modul%20baglantısı.pdf
one
PSA MODULE CONNECTION PROCEDURE
(PEUGEOT 307)
In today's vehicles, fuel gauges are connected to the lever arm inside the fuel tank.
Reflection of the electrical signals produced by the variable-valued resistance element to the instrument panel
works on the basic principle. However, the situation is different for vehicles such as Peugeot, Reunault and Citroen.
In these vehicles, the warehouse samirage, fuel only once in the tank after refueling
reports the amount to the electronic control unit and the task ends at this point. After that, electronics
how much of the engine using the control unit, petrol injection time, and engine speed signals
by calculating the amount of fuel spent, the amount of fuel consumed from the first value sent by the samantha
It reflects the value obtained by subtracting to the dashboard. Therefore, fuel indicator in these vehicles
There is no direct connection with the warehouse samara. Petrol injectors when the engine is running on LPG
it does not consume gasoline as it is put to sleep, but the gasoline ECU will not run
continues. So the fuel gauge also shows that until the next refuel, the vehicle will
falls as if he wasted it. When the refueling is done, the electronic control unit
perceives its change. It reads the amount of fuel again from samanda for 1 time, the fuel indicator is correct
shows the value and starts executing the described algorithm.
The PSA module cannot prevent the fuel gauge from falling, but every time the ignition is turned off and on
electronically misleads the electronic control unit as if it was refueling. if
emulates as if the level change in the fuel oil, and the fuel gauge is also correct
shows the amount of fuel.
The connection described in this document is by opening the cover under the rear seat of the vehicle.
It is made to the connector on the fuel pump and the samarara.
2nd
Cable number 1 is the samarada signal cable. This cable is cut. PSA to the cable on the installation side
the module's white cable is connected (cable number 2). PSA to the cable on the connector side
the white-orange cable of the module is connected (cable number 3) (Picture 1)
Picture 1
3
Cable number 4 is the samarae cord. This cable is stripped and the PSA module is black and white.
cable (cable number 5) is connected to this cable. (Picture 2)
Picture 2
4
Cable number 8 is the base cable of the fuel pump. This cable is stripped and the PSA module is black
the color cable (cable number 9) connects to this cable. Cable number 10 of the fuel pump
is the positive cable. This cable is stripped and the brown cable of the PSA module (cable number 11)
it connects to the cable. (Picture 3)
Picture 3
5
Finally, to the + 12V connection, which does not cut even if the contact is closed for feeding the PSA module
is needed. Supply cable number 6 in the fuse box in the driver's room in this vehicle
It is stripped and connected with extension cable number 7 and taken to the back. PSA module red
colored cable is connected to this extension cable and fed continuously. (Picture 4)
Picture 4
All connection points must be definitely soldered, insulated with macarons or insulating tape. PSA
module should be placed in a place away from water, dust and heat.
6
CONNECTION SEMA:
08.05.2020 15:02 # 2
g-demir
Health to the labor of my friend. get it from me When the vehicle closes the vehicle for 20 seconds while closing the vehicle, the brain resets the data, including the fuel condition.
08.05.2020 15:02 # 3
sercinho
We tried it, there is a problem in me right now, it is not LPG, but the medicine is stuck with me. Even though I do not press for 20 seconds, there is no improvement.
08.05.2020 15:02 # 4
g-demir
as standard, it should detect at 2 - 3 liters. If you fill the tank completely and make the sensor sensor a ceiling? If there is a hang-up situation, maybe it will get comfortable while swimming in gasoline?
08.05.2020 15:02 # 5
sercinho
I will try tomorrow, let's see water software, the heat did not lie on my head, sagolas for your information
08.05.2020 15:02 # 6
BAHTIYAR
None of this is necessary, 60% of your tank is full, the bar never goes down, I bought 110 lira of gas once, then I get 20 lira each month.
08.05.2020 15:02 # 7
metin
How do you share the psa module, it would be better if you shared it.
08.05.2020 15:02 # 8
sercinho
friends be psa module in Ankara, if you want goral and abc to the vehicle, if you want to add a 100 TL difference, if you do not have it, then you can not install it afterwards, 2a can write it with engineers and install brc in the original services. It may change according to the city you are in.
08.05.2020 15:02 # 9
metin
Anybody who knows how to wear nekadara who has knowledge in their environment, share it with friends. For example, I have a module, but I am not happy at all, sometimes it shows half the warehouse halfway.
