The smell of oil on the way |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:58 | # 1 |
friends, I came across this problem twice, while on the way, I suddenly smell of oil. |
| 08.05.2020 15:58 | # 2 |
urgently go to a mechanic ... an unmissable subject ....
| 08.05.2020 15:58 | # 3 |
Are you able to distinguish between oil smell or diesel smell?
| 08.05.2020 15:58 | # 4 |
Is there an oil leak etc on the engine ??? or an oil splash etc on the exhaust ???
| 08.05.2020 15:58 | # 5 |
I say take a good look on the engine, if there is a slight leakage in the gasket, it smells because of the engine temperature. |
| 08.05.2020 15:58 | # 6 |
muzarix |
My friend has a similar problem too, the first time I start the heater, it causes 1-2 drops of oil leaking from the gasket. It disappears after 3-4 minutes. If there is no serious oil leak like mine, open the windows the first time you open the heating system. But if it is a recurring situation, you should have it checked.
