The smell of gasoline coming into my car
08.05.2020 19:55 # 1
bozlak
After changing the gas float of my car, what could be the reason of the smell of gasoline in the car especially in hot weather?
08.05.2020 19:55 # 2
the float may not be fully seated. There is no other alternative if there is a smell inside the vehicle.
08.05.2020 19:55 # 3
sevipalma
The float is missing the cover
08.05.2020 19:55 # 4
bozlak
How many times the Samandira was disassembled and not tightened on it, they were tightened on the cover.
08.05.2020 19:55 # 5
then, I do not think of anything else in the engine compartment fuel hoses.
08.05.2020 19:55 # 6
bozlak
The smell does not come all the time when the ramp goes up in the hot weather.
08.05.2020 19:55 # 7
Dlkrn_48
Does the vehicle have LPG?
08.05.2020 19:55 # 8
burakugur
I had the same problem, and I would have smelled on the ramp and the ramp. You should change the tank gaskets.
08.05.2020 19:55 # 9
ersinyildiz
In the past months, when I filled the tank completely, I started to smell like this, I didn't care at first, but when the smell did not decrease, I had the electrician look at it. Under the right rear seat there is a gasket in the place of the gas pump. Over time, it loses its feature. When we opened it, we saw that the gasket was broken at one point.
I think if you fill the tank completely, you will encounter a similar problem. On the slopes, the gasoline level is probably missing when it comes to the gasket level. It costs 50 TL, it's not worth boring. Get well soon
08.05.2020 19:55 # 10
horoz28
I do not have such a smell, but when I clean the car, let me remove it :) I do not know my car yet.
08.05.2020 19:55 # 11
palet
It is useful to replace the rubber seal under the tank float cap. If the smell continues despite the change, a canister replacement may be required.
you can see the topic of canister if you search with the title below
"evoporation canister-gasoline ventilation"
palette 2016-07-29 19:21:05
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
