the smell of gasoline |
| 08.05.2020 16:58 | # 1 |
| 08.05.2020 16:58 | # 2 |
volkan22 |
I think you can lie under a car, look at the smell warehouse, if it is, it is possible that one of the hoses came out if the tank was not punctured.
| 08.05.2020 16:58 | # 3 |
monur |
[QUOTE = farewell] & nbsp; When my car passes half the tank, it smells of gas and anyone who gets it repaired (307sw 1.6 16v) thanks ) find the float of the cloth and open the contact leaks if there is a crack in the end of the inlet and outlet hoses. It is the chronic problem of Peugeot.
| 08.05.2020 16:58 | # 4 |
volkan22 |
Congratulations my brother, the same problem is taking care of me 2 out of the ward is a cover under the back seat. When I take it out, there is a petrol samandiras from it. 2 hoses come out from it. I hope it was gasoline from the outlet hose.
| 08.05.2020 16:58 | # 5 |
EErgul |
the same was in my car. If I filled more than half a tank of gas, the horror smelled of gasiness. & nbsp; appeared on the float seal malfunction. I changed it to 15 lira. & Nbsp;
| 08.05.2020 16:58 | # 6 |
EmSul |
Yes, I have the same problem, and today we are a caregiver. In the past, we lifted a fiber, and as you said from the tank, the hoses come from a sharp gas smell, but the master gas tank needs to come down completely, there is a crack in order to look at those pipes, or it may have been a drain hose so that it does not smell in this tank. He said..When the car is running, it doesn't matter with gas or gasoline
| 08.05.2020 16:58 | # 7 |
If it is dripping on the ground, it is from the ventilation hose. if it is half above, it will not be a problem to shake or you will extend the ventilation hose up
| 08.05.2020 16:58 | # 8 |
EmSul |
Yes, I think the master could not understand this from the ventilation hose. My father understood it at once, because it was in one of my father's vehicles, because the ventilation hose was displaced, I could smell it from him. the warehouse has to come down because united he said it will also work, let's see the master in malatya, what will my master in balikesir say & nbsp;
