The screen is ok. How do I change the indicator light
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:08 # 1
muro_60
it is not hard at all. You can see it with 12 small LEDs. I just made it red.
08.05.2020 18:08 # 2
samet206
It is not a difficult operation, if you have already made the watch, you do it too, but I recommend you to choose colors that will not be eye-catching while coloring, if the original colors are adjusted accordingly, it will start to tire too much after a certain time. Be careful that all the lights are evenly distributed. the part becomes dimmer, such errors can be made You understand the process to be done when you remove the panel already. it is enough to disassemble.
samet206 2013-12-18 13:27:04
08.05.2020 18:08 # 3
zorvolkan
it is not related to this subject, but I want to state my problem.
08.05.2020 18:08 # 4
zorvolkan
[QUOTE = 307bursa] [QUOTE = zorvolkan] is not related to this subject, but I want to indicate a problem. When I first run the car, it becomes fading and unreadable after a while when the colors and texts are very obvious. [/ QUOTE]
the bulbs have completed their lifetime and will be improved when you renew them
thanks buddy. i just can't dare to disassemble it :)
08.05.2020 18:08 # 5
reality59
Hodja, you said white transparent tracing, but I did not fully understand this place.
08.05.2020 18:08 # 6
reality59
Up to date? :)
08.05.2020 18:08 # 7
lthec
The 307s' own screen becomes faded as the temperature rises. I also increased the light with the led and made the color of the screen blue using blue acetate, but at first the screen, which was very vivid, used the car and then became faint when the temperature inside increased. That's why I used to remove the faintness with the new generation 206 screen, but only the radio remained in operation this time. cd reader and multiple cd player are disabled.
08.05.2020 18:08 # 8
lthec
In the meantime, when removing the orange layer behind the screen, heat it with the hair dryer and remove it, it is both easily removed and the possibility of damaging the film layer in front of the orange is reduced.
08.05.2020 18:08 # 9
reality59
[QUOTE = 307bursa] [QUOTE = reality59] My teacher said you are a white transparent trainer but I didn't fully understand this place, can you open it a little? [/ QUOTE]
I missed the life message sorry
You can find your tracing paper in stationeries.
I used 2 pieces of tracing paper in the dimensions of orange paper and I'm very satisfied
thank you bro :) let's be my first job on my day :)
08.05.2020 18:08 # 10
tolga.onal
While performing the process, the film-shaped conductor that connects the screen to the motherboard has been peeled a little from the edge and does not stick again. I do not have a new screen.
08.05.2020 18:08 # 11
tlp
The lighting in me was made of LEDs.
normal plug out not bulb
if so, I think electronic intervention will be required to replace it
08.05.2020 18:08 # 12
serkomser
I removed the orange plate, put some tracing (4 layers), but the back screen was black, I didn't like it. When the writing was faint, I put the orange plate again. The result is longer articles, but after 20 minutes (when the air conditioner is turned on), it becomes pale again. I put a hammer on it divided into 3 :) but I am comfortable.
08.05.2020 18:08 # 13
serkomser
Where is the screen? Glass panel?
08.05.2020 18:08 # 14
tolga.onal
[QUOTE = eurest] I put a bi in the attractive 3 divided :) but I am comfortable. [/ QUOTE]
It will be like grasping the subject, but every time I see it, I laugh you did the best brother Alkış
08.05.2020 18:08 # 15
serkomser
I recovered later, now it is running very smoothly :)
Note: In the morning, I drove the car on the sidewalk, I think the right front side, the bumper side part and the glass washing water canister were pierced, I think water was coming under the car, so I left it. Isn't it anything else?
08.05.2020 18:08 # 16
tolga.onal
The glass water tank is on the right side, but it was not in a position to be drilled by knocking it from the bottom. will it continue
08.05.2020 18:08 # 17
tolga.onal
if it flexes rather than puncture, the hose to the wipers may have loosened or loosened from its place
08.05.2020 18:08 # 18
serkomser
I didn't knock Tolgac, I rubbed the bumper because it was flexible, it must have pressed the bin?
If [QUOTE = tolga.onal] is stretched rather than punctured, the hose to the wipers may have loosened or loosened [/ QUOTE]
I think so, but I said a question.
Eurest 2014-05-13 09:41:38
08.05.2020 18:08 # 19
Serkan
Well, sir, the water outlet is at the bottom of the canister, the sprinkler motor is directly entering the canister and the engine has been displaced.
08.05.2020 18:08 # 20
serkomser
Thank you, we lifted the hose from the displaced fiber and put it on.
Our worst problem is this, thank you, the rest is not a problem.
