the right wheel of my vehicle is tilted from above
08.05.2020 20:01 # 1
mertgokhan
Hi
friends, the right wheel of my vehicle is leaning inward, the upper part of the right wheel is leaning inward, my left wheel is flat, what is the normal cause?
08.05.2020 20:01 # 2
Have you ever been in a hard pit? Sallıncak - check the axle carrier, I would recommend you to go slowly if you are going to use it.
08.05.2020 20:01 # 3
mertgokhan
I did not go into a hard hole, but you did not feel in such a hard situation.
08.05.2020 20:01 # 4
mistercasper
Go to a rot balancer.
08.05.2020 20:01 # 5
mertgokhan
There is a situation like this, when I go into the light pit while going fast, there is no problem in front, but when one of the back abandoners enters, it is as if my car is swinging from left to right.
08.05.2020 20:01 # 6
Then, as our teacher friend said, go to a good rot balancer, this type of swinging problems is because the balance and rot order are bad.
08.05.2020 20:01 # 7
GokhaN
If there is such a trapezoid, I would say go to the chassis and measure the camber before the rotcu.
08.05.2020 20:01 # 8
TugyyStyle
If the vehicle is 206 and the rear wheel is no problem :)
08.05.2020 20:01 # 9
mertgokhan
No teacher, 307
08.05.2020 20:01 # 10
ben_erhan
Friends, there are 2 right wheels in the vehicle. Front and rear right wheel. Which one is mentioned here.
If the front wheel is to be looked for parts such as shock absorber rod heads, swing, axle, z-rod. I don't think it will tilt the wheel in the front shock absorber problem.
if it is the rear wheel, there may be skewed axle and it is obvious if you have entered the rod setting.
If you use it this way, the wheel will wear out ... it has already been worn out .. you will see it as soon as possible or you will have both repair and wheel costs.
I hope it has a cheap solution.
08.05.2020 20:01 # 11
OguzhanKucuk61
I noticed a situation like this in my vehicle. With the steering wheel turned full turn to the left or right, the front tires lie towards the turned side. So it's the shape of the Mercedes. I said to the master, he struck the wave, said you will get a better bend. What is the reason of this. I am not satisfied with the front or back comfort. Do I have to get a front set and torsion?
08.05.2020 20:01 # 12
yigit_dark
If only you had been informed that it was resolved or not resolved. I have the same problem, I think I would have received information from you.
08.05.2020 20:01 # 13
JunioR56
In my vehicle, we leaned a little inward from the side that stepped on the left front wheel. The subset has completely changed. z rod carrier rod shaft head shock absorber mounts. When we entered the rod setting, we noticed that the wheel was crooked. He said that the place we tighten with bolts could be skewed by an accident. I use it like that.
08.05.2020 20:01 # 14
fætih
If the front tire is turned full turn from the left side, it lies slightly. The vehicle gives camber so that it doesn't travel. it is so in all vehicles.
08.05.2020 20:01 # 15
JunioR56
Mine is still flat on the steering wheel.
