The right to choose tires.
08.05.2020 15:06 # 1
fahrikem
ornijal michelin energee 175x65x14 tire in my pejo 206 xr 1.4 automatic gear car I am thinking of selling the current vehicle in 1, 2 years but the tires want to crack from the cheeks and some parts of the teeth have started to be tire. The quality is very good, but the price is quite high. Also, 175x65x14 tires do sometimes tossing in bends. In this case, thanks to which tire and brand with the surface that touches the floor without changing the rims will see my work.
08.05.2020 15:06 # 2
If you want anything to see the heat, you will take a look at the price. Your size is not too expensive anyway. I think it will not exceed 120 lira if you buy the knife. I guess that you can find up to 70 tires according to the brand. but I do not recommend buying a very hard tire. You will need to hold on, come and say that I should buy a good tire. There are troubles such as not keeping balance in flat tires. I think don't miss the heat. it provides a rubber connection to the road ... as well as peeling from me ...
I have the bridgestone B330 in my car and the tires are exactly 5 years old. I think it is loud but durable. I am happy to hold on to all kinds. Brake and cornering performance is good on wet or dry ground, although the outside is in the middle.
08.05.2020 15:06 # 3
fahrikem
I think soft tires are silent, in this context, which brands should I choose from soft tires?
08.05.2020 15:06 # 4
BAHTIYAR
I suggest using most taxi drivers, they say they are satisfied, both domestic production and cheap
08.05.2020 15:06 # 5
metin
I recommend the nokian H model.
08.05.2020 15:06 # 6
[QUOTE = fahrikem] I think soft tires are silent so which brands should I prefer soft tires [/ QUOTE]
The soft tire is silent as it is said, but this time the grip is weakened and it melts faster ...
You have to look at a tire that has a good balance.
08.05.2020 15:06 # 7
arsgok
I recommend nokian too it is really quiet and soft I used michelin and dunlop before but this is really nice you are pleased h it is a little hard.
08.05.2020 15:06 # 8
arsgok
or if you want something cheap, you can think of barum (continetal by-product) check or hankook
08.05.2020 15:06 # 9
klemann
I recommend Kleber. by-product of michelin. soft and very durable. Very affordable in price. I say buy it 185/55/14 but it does not suit tin rim
08.05.2020 15:06 # 10
[QUOTE = Klemann] I recommend Kleber. by-product of michelin. soft and very durable. Very affordable in price. I say 185/55/14 but it does not suit the tin rim [/ QUOTE]
Let's not make a wrong route to my friend ...
I don't have a word about the brand, but 185-55-14 never happens in place of the tire 175-65-14.
this is 4.1% smaller than the original one. In addition, it is the original measure of 106 gti.
08.05.2020 15:06 # 11
fahrikem
In my car, the 14 inch rim on the pejo 206 has its own original rim and 175x65x14 on the tire.
08.05.2020 15:06 # 12
[QUOTE = fahrikem] In my car, the 14 inch rim on the pejo 206 can use its original rim and 175x65x14 on the tire, I want the car to hit the ground better on the original rim.
You can't change the tire size according to your head. The point you should pay attention to is the rubber cap. If you do 185 or 195 without changing the sidewall, you will get the rubber cap. It is necessary to reduce the height of the cheek from that pain. If you put 185 60 14 in place of the tire itself, it will be 0.9% small. If you wear 195 60 14, 1.1% will be bigger. preference is up to you here ...
08.05.2020 15:06 # 13
fahrikem
Well, would any drawback occur in the 2 cases you mentioned? In which case sn.cecoli the vehicle presses the ground more firmly
08.05.2020 15:06 # 14
by-cx
So guys, wouldn't it be a thin sidewall tire on 14 wheels?
08.05.2020 15:06 # 15
Nokian, Yokohama, Hankook, Toyo, Kumho are soft.
In terms of price / performance, I think Hankook is the best ..
08.05.2020 15:06 # 16
[QUOTE = fahrikem] Well, does this cause any inconvenience in the 2 cases you mentioned? In which case sn.cecoli the vehicle presses the ground more solid [/ QUOTE]
Of course 195 provides a better adhesion since it is wider ... but it affects the price :))
08.05.2020 15:06 # 17
[QUOTE = by-cx] so friends wouldn't have a thin sidewall tire on 14 wheels? [/ QUOTE]
If the aim is to thin the cheek, the only condition is to not change the total cap of the tire.
You cannot install a thin sidewall tire without the wheel and wheel of the gauge mentioned above. The cheek is already from 65 to 60 dust, but that is all. but you can't fall further down ...
08.05.2020 15:06 # 18
[QUOTE = berkaygr] Nokian, Yokohama, Hankook, Toyo, Kumho are soft.
I did not say it was expensive but I said I would support it when you say it.
I used the yokohama C.drive with 185 60 14 and I was really pleased. he is still using it at the top of the spruce. It has been 80,000 km and 4 years but its performance is still very nice.
08.05.2020 15:06 # 19
by-cx
cem brother is now in my car 206 1,4 otm. neither measure is good both visually and performance Ouch
08.05.2020 15:06 # 20
klemann
I recommend [QUOTE = cecoli] [QUOTE = terminal] Kleber. by-product of michelin. soft and very durable. Very affordable in price. I say 185/55/14 but it does not suit the tin rim [/ QUOTE]
I think you think you are onno master;) 185/55/14 as small as you want, but it will press the ground well from the original tire. I don't know where you are looking for a tray you found, but make sure it is correct, then comment.
Page : / 2
