the right rear door does not open
08.05.2020 16:33 # 1
muhammed43040
I did not get into my 307 car for a long time, I said let's go to a market today, friend could not open the back door, I pushed it from inside again, I did not open it again, I tried to lock and re-open the door again. .
[TUBE] pozWjkLrhPg [/ TUBE]
08.05.2020 16:33 # 2
yavuz25
the door has to be dismantled. The child is not locked.
08.05.2020 16:33 # 3
muhammed43040
I am afraid I will break it. If there is someone who has never dismantled the back door at least, if I give a little bit of information, I can do it myself. Thank you.
08.05.2020 16:33 # 4
yavuz25
Nothing to be afraid of.
It's described here. It can give you an idea.
08.05.2020 16:33 # 5
06OzGuR06
Central lock problem "Smile" There is a central kilt engine that allows to lock and open the door in the door. The problem seems to be the door trim. electrical control should be done, whether the motor is receiving electricity or not. If the electricity is coming, the lock motor will be defective. "Smile" "Wink"
08.05.2020 16:33 # 6
yavuz25
[QUOTE = 06ÖZGÜR06] Central lock problem "Smile" there is a central lock motor inside the door to lock and open the door. . The door trim should be removed and checked. Electricity should be checked. Whether electricity is coming to the engine or not. If the electricity is coming, the lock motor will be defective. /> "Wink"
this is
08.05.2020 16:33 # 7
My brother, I couldn't dismantle that back door or you should be very careful and careful. it stretches so much as if it will break. be careful if you intend.
08.05.2020 16:33 # 8
bulent 77
the door might be frozen
08.05.2020 16:33 # 9
yavuz25
[QUOTE = bulent 77] door might be frozen [/ QUOTE]
unfortunately. "Smile"
08.05.2020 16:33 # 10
muhammed43040
there is no possibility of freezing in the garage lock is working lock is locked when I open and open the door, there is a locking sound
08.05.2020 16:33 # 11
06OzGuR06
[QUOTE = muhammed43040] There is no possibility of freezing stops in the garage lock is working Locking sound is opened when I lock and open the door
< br>
Well if the engine is running then it means there is a mechanical problem. The door trim needs to be removed for any possibility. A part inside the door may be broken or dislocated. It seems difficult to understand without dismantling. "Smile"
08.05.2020 16:33 # 12
muhammed43040
If I knew how to disassemble it, there are not many masters in Kütahya, let me take it without breaking one side
08.05.2020 16:33 # 13
06OzGuR06
[QUOTE = muhammed43040] how to get rid of it, i don't have many masters in Kütahya, let me do it without breaking the side
Take it to an auto upholsterer then but tell it from the beginning carefully & nbsp; dismiss "Smile" After breaking and pouring, there is no meaning. "Smile"
08.05.2020 16:33 # 14
06OzGuR06
If you want to take a look at this issue, if I think the 307 front door trim is removed, I don't know if it is the same for the back door "Smile"
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=6 Member Reviews
08.05.2020 16:33 # 15
Kemanyak
Dude the problem is in the lock mechanism. It was the same for me. It doesn't open from the inside because you probably left the child lock active. It cannot be opened from the outside because its clay mechanism is closed. Vel-made speech; The action you can do is to remove the door from its hinges and deactivate the child lock. The deactivated child will be able to be opened from inside through the lock. Then take the lock mechanism out of the door. You will repair and replace the gear connected to the motor inside & nbsp; motor (rust remover WD40 and Grease).
08.05.2020 16:33 # 16
Kemanyak
You cannot disassemble the seats and pillars do not allow.
08.05.2020 16:33 # 17
muhammed43040
it is very bad then either, if the door is removed, they must have changed, there must be a way to break it, if necessary, I will break the interior floor and find a new one or more
08.05.2020 16:33 # 18
yavuz25
[QUOTE = muhammed43040] it is very bad then if the door is removed, they must have changed, there must be a way to break it, if necessary, I will break the interior or find a new one or
disassembling from the hinge is crippled. We removed the palion from the inside because the door was not opened. We had the same problem. "Wink" I don't think the piano will be down. "Wink"
08.05.2020 16:33 # 19
muhammed43040
I do not handle the hinges anyway, the vehicle doesn't even have a 2002 model paint, I break the door trim or talk to a service tomorrow.
08.05.2020 16:33 # 20
yavuz25
[QUOTE = muhammed43040] I do not handle the hinges anyway, the vehicle does not even have 2002 paint, I break the door trim or talk to a service tomorrow. div> [/ QUOTE]
my brother takes care of a familiar electrician. Not so important. Don't go to the service. Something simple already. "Wink"
yavuz25 2012-01-26 20:46:47
Page : / 2
