The rear fog lamp is not lit ??
08.05.2020 19:07 # 1
vpro
Friends, the rear fog light is not on. Is the bulb or something?
08.05.2020 19:07 # 2
106fb
Check the fuse first, if not, it is a light bulb.
08.05.2020 19:07 # 3
riderzist
Most likely, the bulb. Do not buy one by one while buying bulbs anyway 3 4 stop take 2 3 park take your backup, let it change 1 minute event .. the bulb will explode in a few years. Something for £ 1
08.05.2020 19:07 # 4
vpro
I looked at this day, can I remove contactlessness in the senses. Stern Smile
08.05.2020 19:07 # 5
vpro
at this time, the right front dipped beam is not lit: D: D is long and the park is lit
Meanwhile, I have pressed the aluminum foil into the socket: D
13.12.2021 03:41 # 6
osman_2626
Did you remove the rear fog? It gave me a lot of effort but I couldn't take it off. It is not a led system but a normal standard yellow bulb, I guess, it should come out when I turn it left and right, but I couldn't remove it.
What can I do?
