The rattling noise that comes in the reverse gear
08.05.2020 17:29 # 1
fenersel
A voice that bothered me that I noticed as of yesterday started to sound;
My car is 106 xr 5 doors.
When I put it in Reverse Gear, there is a clattering sound on the first take-off, as if something crashes somewhere 3-4 times and then ceases to be full.
what do you think could happen.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=26023&title=evrim-baly is
fenersel 2013-04-01 10:39:40
08.05.2020 17:29 # 2
angarya0061
There is no problem when replacing the back pads, trouble is the back pads are finished or moved
08.05.2020 17:29 # 3
Where does the sound predict come from?
08.05.2020 17:29 # 4
fenersel
[QUOTE = koliva] Where does the sound predict come from? [/ QUOTE]
I don't have a lot of technical knowledge, but the sound comes from the back and the bottom of the car. I cannot distinguish it as right-left because it comes neither from the right nor from the left.
08.05.2020 17:29 # 5
fenersel
[QUOTE = angarya0061] There is no problem when replacing the back pads, the trouble is that the back pads are finished or dislodged [/ QUOTE]
but it only comes up in the reverse gear. How many times have I tried to get up in 1st gear, there is no sound.
08.05.2020 17:29 # 6
angarya0061
I do not do the 1st gear, but I do not have the same problem, I had the same problem.
08.05.2020 17:29 # 7
fenersel
[QUOTE = angarya0061] 1. I don't have gears, but I do not have the same problem, as I have faced the same problem, I was able to remove the grooves.
Then again, the way of industry appeared to me, let's see, well, I hope it is not a very expensive thing.
thank you for your interest.
08.05.2020 17:29 # 8
angarya0061
the same, it doesn't cost much, you are welcome.
