The rating on the information display shows wrong
08.05.2020 15:11 # 1
sace
Greetings. 2002 The 307XR shows extremely high value on the information display and is flashing. So it shows 30 degrees even in winter. How can I fix the problem?
08.05.2020 15:11 # 2
Ozgur
Introduce yourself first.
08.05.2020 15:11 # 3
sace
I'm Celil from the soup and 307 users for a few months.
08.05.2020 15:11 # 4
dinoco
at wrong temperatures
08.05.2020 15:11 # 5
oguzhan29
There is a problem, of course, friends who have knowledge about it will return to you
08.05.2020 15:11 # 6
tigerland
[QUOTE = sace] I am Cellu from soup and 307 users for a few months. [/ QUOTE]
Hi welcome. I also live in soup. There is a peugeot electric master on the subject, Ersoy Ergin I can direct you there. they help
08.05.2020 15:11 # 7
[QUOTE = sace] Regards. 2002 The 307XR shows extremely high value on the information display and is flashing. So it shows 30 degrees even in winter. How can I fix the problem? [/ QUOTE]
The thermocouple (thermistor), which is the temperature of the outside air, is located in the exterior mirror on the passenger side. Even when you look in the mirror, it manifests itself with a black rift. Probably your sensor is malfunctioning. It is not expensive, you can even change it yourself. Even the diagram is as follows:
Koliva 2011-03-25 16:26:46
08.05.2020 15:11 # 8
tigerland
@koliva supersin :) you never go to the service, you have solved everything, do you have a quote or do you have documents about peugeot or are you working in the service? Gülme
Nice share :)
08.05.2020 15:11 # 9
[QUOTE = tigerland]
nice sharing :) [/ QUOTE]
No, these issues are completely opposite with my field of study. I just read a lot and follow the foreign websites. I also have a Peugeot SEDRE Backup program on my computer. I usually take pictures from there or find them on the internet. I find it easier to find the ready to download from the Internet. Göz Kırpma
08.05.2020 15:11 # 10
dogu
I think the temperature measurement unit, which is celcious (C), has probably turned to fahrenait (Fr).
08.05.2020 15:11 # 11
[QUOTE = east] I think the temperature measurement unit, which is celcious (C), has probably turned to fahrenait (Fr).
This is not the case for me, but when I said "studying degrees", I eliminated this part directly. But you have touched a nice point. In fact, its flashing is also a warning against the risk of ice. According to 32 degrees Fahrenheit = 0 degrees and if the user's location is cold, it is both flashing and reading 32.
08.05.2020 15:11 # 12
sace
Thank you all for your attention. After reading these, I went to the car and started to tamper. It was also in my mind to show it as Fahrenait, but I did not know how to translate it. Now it was showing 48 ° when I left. I pressed the button on the left, nothing is left on the screen. Clicking a few times comes the date setting. It goes without adjusting them in 3 moves, day after year, year. I tried again and pressed the right button 1 time on each blank screen, the result improved to 9 °.
08.05.2020 15:11 # 13
dogu
good luck .. :)
