THE PROBLEMS ARE EACHING EACH OTHER
08.05.2020 17:02 # 1
doomer55
Good evening. I just joined you with 2006 307 hdi 110 hp premium. I love my car very much, but the minor problems aren't interrupted.
PROBLEM 1: When I pull my foot out of the gas above a certain speed, a car jolts. As if the engine is playing from the ground.
PROBLEM 2: The metal rubbing sound comes from the engine while accelerating with the car. Does it take too late while working? Could it have something to do with it? & Nbsp;
PROBLEM 3: Depollution system faulty article is out of my way too. Then it went out on its own, but now my vehicle is knocked once in 2-3 minutes with my movement.
Despite everything, I don't change the course of this vehicle to anything. If you find a solution to my problems, thank you in advance.
08.05.2020 17:02 # 2
metin
Hello there. I will try to answer your problems one by one. & nbsp;
problem 1: You should look at the engine and transmission ears. if there is a gap it can do. & nbsp;
problem 2: I do not think there will be a connection between the engine running late and the friction sound. the starter engine fuel system may be vsvs.
problem 3: the problem may be fuel related, and it will be better for you if you maintain your filters every 5,000, not 10,000. / div>
08.05.2020 17:02 # 3
doomer55
thank you text brother. I will look at it & nbsp; at the first opportunity. I hope it doesn't cost much. Although it is hungry, our neck is now in debt.
08.05.2020 17:02 # 4
MagicPerformance
your trouble is most likely caused by the engine's ear.
08.05.2020 17:02 # 5
doomer55
Waiting for help from the masters? Güncelll ...
08.05.2020 17:02 # 6
soner09
the ear of the motor is located in the upper and lower parts of the motor, it came to press me, the broken car is shaking officially, I think it is the room, I hope the problem will be solved soon
08.05.2020 17:02 # 7
berk2309
& nbsp; look at the bearings of the triger apricot for metal whistling sound & nbsp; sometimes they are making sound sounding like metal surtuyomus sound sound & nbsp; berk2309 2012-09-18 19:29:12
08.05.2020 17:02 # 8
doomer55
Actually the triger has also changed but it may be as you say. & Nbsp; thanks for your comments.
08.05.2020 17:02 # 9
307 afyon
the same problem happened to me, I did a trip to the black sea, I did 3000 km, nothing happened, but the depollution system malfunction on the way back, but there was no abnormality in the car 2006 lpg automatic 307 vehicle was fitted with a tube, it was 500o km, I took the vehicle to the service, I changed the air filter, put out the fault, but after 2 days again burned & nbsp; this time I took it to the tuber, he put it out, but after 3 days, the light went on again, there is no abnormality other than the light is lit, I said, let's cancel the traction is very good, do not need any other advice. then he works again with the starter, he did it 3-4 times .. waiting for your suggestions and suggestions
