The problem with my 206 vehicle. Take a look and give an idea .. |
| 08.05.2020 17:03 | # 1 |
This malfunction does not always happen. Occasionally. Speedometer drops to zero while driving. The engine malfunction lamp starts flashing and the vehicle's traction drops. If I stop, that is, if I stop giving gas, it stops. Then, the car continues on its way as if nothing was running. As if there was no problem at all. When the speed of the vehicle reaches 45-50 thousand, the vehicle begins to shake.
| 08.05.2020 17:03 | # 2 |
In fact, the speedometer had not dropped to zero when he gave this fault the other day, but had stopped when the vehicle's traction had dropped. I continued on my way as if there was nothing when I started it again and there is no click for 2 weeks, the vehicle is working properly.
| 08.05.2020 17:03 | # 3 |
When the engine fault light is on, what is written on the screen is & nbsp;
| 08.05.2020 17:03 | # 4 |
What is the vehicle gasoline diesel engine kac & nbsp;
| 08.05.2020 17:03 | # 5 |
In my car, the speedometer has recently dropped to zero, then it is recovering, so it started to do it frequently. Today, the airbag light came on, when it stopped for the first time, it went out.
| 08.05.2020 17:03 | # 6 |
brothers tickle the battery and the car's charge will happen in me.
| 08.05.2020 17:03 | # 7 |
My car is gasoline 2001 model 1.6 XT My screen in the center console is not working and I cannot see if there is a fault message. Battery is new and they looked at the charge measurement while it was being attached. I just replaced the spark plugs and the coils that supplied them with electricity. I don't think it will be from them either. I don't understand, it's just that if the indicator is just not going to fall off the power, the indicator is defective. There is no problem when you stop and start again. When it's okay, repairers can't find a heck.
| 08.05.2020 17:03 | # 8 |
No teacher, I did not tell you, I said it to the ndm01 friend: Have the D speed sensor checked. Bidet the computer.
| 08.05.2020 17:03 | # 9 |
the same thing happened with me
| 08.05.2020 17:03 | # 10 |
Many thanks to the friends who answered. As I said, the vehicle doesn't always give this fault. Does this happen when the speed sensor fails? I wonder how many lira this is. Is there any place you can recommend in Ankara that understands this business? I will say go replace it.
| 08.05.2020 17:03 | # 11 |
actual
| 08.05.2020 17:03 | # 12 |
In my opinion, it is not a problem that you have touched at all. I did not understand what a vehicle, festivities to the houses. The speedometer sometimes does not work, the airbag lamp sometimes illuminates, the engine fault light sometimes illuminates, the door sensors do not detect: (& nbsp;
