The problem that I can not find the solution in thinking |
| 08.05.2020 18:44 | # 1 |
| 08.05.2020 18:44 | # 2 |
There are problems with the axles, master. most likely in the long one on the right axle. If there is no problem, the print looks at the pad. this is usually the general problem of most people with 206. The springs of the vehicles are cut and brought closer to the ground, then the joints of the axle wear out the tulip. The vehicle vibrates like an oil-burning corset in the result of sudden gases |
| 08.05.2020 18:44 | # 3 |
Alicilik |
If it is between 90-120, it is from axle ball. It is cut after 120. Auriste sounded like the plane engine was running in the car in that speed range. |
| 08.05.2020 18:44 | # 4 |
At 110 km speed, my 206 was shaking a lot, because of the rims, four wheels were fixed from 20 tl. |
| 08.05.2020 18:44 | # 5 |
Can it also play axle vibration gear lever? These are the main roles of the shaking problem from the engine heads that can be made from the balance adjustment. |
| 08.05.2020 18:44 | # 6 |
Efe-Pojo |
The friend, who said it only happens when the gas is pressed, reinforces the possibility of this axle.
| 08.05.2020 18:44 | # 7 |
[QUOTE = samet206] Can it also play axle vibration gearshift lever? These are the main roles of the shaking problem from the engine heads that can be made from the balance adjustment. [/ QUOTE] The gear selector already turns like whirling dervishes at the moment: D: D |
| 08.05.2020 18:44 | # 8 |
[QUOTE = Efe-Pöjo] said that it only happens when the gas is pressed, this axle strengthens the possibility. [/ QUOTE] Then I'll have my axles checked. I do not want to spend a lot of money and replace a piece that does not have any malfunction from the industry. |
| 08.05.2020 18:44 | # 9 |
Playing the gearshift lever indicates that I am a problem ?? or whatever he plays violently I play very lightly on the gas and pull it out
| 08.05.2020 18:44 | # 10 |
ahmed206 |
Playing the [QUOTE = serkans] gear lever indicates that I am a problem in the axle ?? or whatever he plays violently I play very lightly on the gas and pull it out [/ QUOTE] Does the gear lever move slightly but the car is shaking? If it does not vibrate, I think there is no problem.
| 08.05.2020 18:44 | # 11 |
no shudder, I wondered if you asked the gear lever to play too lightly.
| 08.05.2020 18:44 | # 12 |
Yes, if the balance adjustment is not a solution, look at the axles. It is likely that the inner tulips have worn and cause tremors.
