The problem of trembling with brake pressure
08.05.2020 19:18 # 1
Beyaz206
Friends, especially at high speeds, the brakes were not felt very much when the brake was pressed, but there was a serious tremor in the vehicle chassis. When I try to waste it for trial purposes, there is also an intense tremor. In this complaint, the transactions made in the service went to the rear drums lathe. The front discs have been turned. It worked, however, 10-15% of the first tremor I feel is still ongoing. Apart from these, what to do and what to look for
08.05.2020 19:18 # 2
sdttn
Wheels-hub bearings-axles
08.05.2020 19:18 # 3
ismailkaya
If you have an accident with your vehicle or if you hit one of the wheels, you probably have a problem with the problem.
08.05.2020 19:18 # 4
Mesut48
If you are still here, replace the pads if they have not changed.
