the problem of stopping on the move
08.05.2020 16:24 # 1
robinx21
hello guys. I have a 2007 model peugeot 407 executive vehicle. I bought the vehicle at 90 thousand and I am the second owner. The vehicle is now at 122 thousand. I have been using it for 1 year. 2 days ago, I bought a euro diesel from the shell at the exit of Antep and started off. I went without any trouble for 200km, then I was going to overtake a vehicle. When I was trying to overtake in the 3rd gear, I went over 3000 cycles and the vehicle suddenly turned on the malfunction lamp. Thank goodness, I stood right to the right without any trouble. GOD has protected, so I started the car again, the fault lamp came on, I continued that way, but this time the vehicle was not getting over 3000 cycles. It was slowly going up to 3000 times. Then I reached the place I was going to go. After the vehicle rested for 2-3 hours, I waited for all the lights to go out without starting the vehicle. The malfunction lamp went out and everything returned to normal. I called a few people why this problem was caused. Some of them said it was because of the fuel I bought. (There is an illegal diesel event in Antep) and some said that the injections should be cleaned. The next day I went to the service, they said it was fuel and they deleted the problems from the computer. I would be glad if friends who have this problem or have knowledge about it help. best regards .. robinx21 2011-11-27 16:13:47
08.05.2020 16:24 # 2
yavuz25
Have you looked at the filter.
08.05.2020 16:24 # 3
Hello,
I also think it will be from fuel. They already saw the error code when they connected to the computer when you went to the service and they told you that it was fuel as a result. If there was a different problem, it would appear in the error code. I hope it doesn't happen again. Get well soon.
08.05.2020 16:24 # 4
robinx21
I have taken care of it while buying my vehicle in 90 thousand. then I had 100 thousand 110 thousand and 120 thousand maintenance. all of them have changed the filters or something, but they have not only replaced the air filter at 120 thousand, they cleaned. I hope my friends don't even live my enemy because it is such a bad situation. The oncoming truck makes a selector and there is a truck that I will overtake with me. There is nothing I can do at that moment. When the other truck went a little bit out of the road, I was between 2 and then when I slowed down on the truck next to me, I walked in front of it and pulled it to the right. Everything could have been worse, not in this way. and so I don't even think of using peugeot anymore.
08.05.2020 16:24 # 5
06OzGuR06
It is necessary to look at what malfunctions the computer shows.If there is a fuel problem, I recommend you buy the fuel from Total.Total Excellium is this fuel additive fuel.
08.05.2020 16:24 # 6
robinx21
There is no problem right now, but I will do what you say and get it from total. Also, since the shell's fuel is known in the world, I am not surprised until today but the problem is at the gas stations. They are playing with people's lives when I say let me win some more.
