The problem of shifting from 4th gear to 5th gear |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 18:50 | # 1 |
2001 106 I have a Quick tool. As I shifted from 4th gear to 5th gear, it sounds as if I did not press the clutch. I do not have this problem when buying from 5 to 4. Transmission oil has just changed, but I'm still having this problem. At the same time, when you want to shift the car into gear, the gear can shift into 4th gear by mistake. What can be the problem? |
| 08.05.2020 18:50 | # 2 |
What pressure is harder?
| 08.05.2020 18:50 | # 3 |
[QUOTE = GökhaN] how hard was the situation that started the press started [/ QUOTE] When you said it was too hard, you were talking about gear changes. If so, it is not too hard or even almost hard, only the sound is very repulsive. Even the clutch set has just changed. |
| 08.05.2020 18:50 | # 4 |
outlaw |
5. GEAR SHIFT Worn ...
| 08.05.2020 18:50 | # 5 |
Is this a problem in the short term? And how much it costs.
| 08.05.2020 18:50 | # 6 |
outlaw |
5. GEAR GEAR IS A CHANGE PRICE, BUT I EXTEND THE EXTENSION ...
| 08.05.2020 18:50 | # 7 |
Thanks
| 08.05.2020 18:50 | # 8 |
5th gear synchromesh, i.e. gear needs to be changed 👍
