the problem of not working in the partner first starter
08.05.2020 21:23 # 1
mcihangire
Hello Friends, I need your help very much
I have a 2009 partner 1.6 hdi vehicle, the engine has been running for the first time in the last year. sometimes 2, sometimes 3 starters. it does this both when it's cold and when it's hot. I thought that the glow plugs changed, the spark plugs changed and the problem continued. handle grip and flywheel reader changed diesel filter changed problem not solved. the pump is also checked, not injector and pump failure. computer does not malfunction. No matter how many repairers I took, they can't say anything.
I would appreciate if you help.
thanks.
08.05.2020 21:23 # 2
My teacher makes air from somewhere, probably you need to check the vehicle fuel hoses. Also, keep the vehicle halfway up the tank and experience the nose on a slope that will be downhill.
08.05.2020 21:23 # 3
mcihangire
thanks.
