the problem of not radio
08.05.2020 19:27 # 1
arif1907
Hi friends, I am not satisfied with the radio of my car. It does not attract any good 2004 model 307. if I take it to the bio that deals with auto tape works
08.05.2020 19:27 # 2
GokhaN
if another antenna doesn't pull before it again, take it to see if it has cable or tape
08.05.2020 19:27 # 3
private
I HAVE THE SAME PROBLEM, REMOVE THE BATTERY, AND KEEP THE RDS SETTLE OFF.
08.05.2020 19:27 # 4
KIZILASLAN
the same problem is with me
08.05.2020 19:27 # 5
ideall35
Don't rush, I think. radios in all vehicles will change soon. Going to digital publishing. then he pulls the net. :))))
08.05.2020 19:27 # 6
ssakyel
Just like the radios that will be broadcast soon, so I recommend you not to make any expenses.
08.05.2020 19:27 # 7
baybaba
I think the story of digital radio broadcasting removes a lot of water, even if passed, the current broadcasting is very long
time continues because it is normal radios, battery hand radios, pocket rather than car radios
what will be the radio features on their phones, they can't just take a nap,
08.05.2020 19:27 # 8
akisioglu
Simply check the antenna socket on the back of the radio.
08.05.2020 19:27 # 9
talip206
Check the socket at the back of the radio, and if your antenna is at the front, flex the glass part of the top lamp from the inside with a screwdriver, remove the glass, then release the plastic part from its fingernails. In some cases, it can take water from there. Check for oxidation, rust.
08.05.2020 19:27 # 10
hamza
take out tape check rear antenna output cable may be loose or disconnected
I got the same problem stature came to my BasicA 2
08.05.2020 19:27 # 11
orcun
See after you have a double screen on the bidet. I do not even have an electrician, the original tape was good again. I regret that I got double
08.05.2020 19:27 # 12
Gilan
I agree Orçun brother's only bad part of the piano is the sound system
08.05.2020 19:27 # 13
burakugur
The same problem exists in me 206 not the original tape. Try not to break your nails. It breaks very quickly and the price of the new one is quite high.
08.05.2020 19:27 # 14
hozer33
If ra and ta keys are pressed, it finds fewer channels.
