the problem of not locking the doors
08.05.2020 18:51 # 1
yapraklar
I wish everyone good day. The doors of my 2010 model peugeot 206+ hdi are sometimes not locked. When I try to lock the doors with the key from the control or directly, sometimes the back doors and the trunk remain open while locking the doors. sometimes they all lock normally. I couldn't find a care, please help if you have any information.
08.05.2020 18:51 # 2
P206HDi
It can sometimes be such troubles. Lubrication of the mechanism may correct the problem.
08.05.2020 18:51 # 3
themurat54
Unfortunately, I have a similar problem.
It caught my attention that when I was driving, I activated the central lock from the inside of the car, then after getting out of the car, I pressed the key's lock key and locked it again, then got back on the car, pressed the central lock key, went out, locked it with a normal key and locked it normally.
If you press and lock in the same way from the vehicle, I think it might be related to it.
08.05.2020 18:51 # 4
ucanturk
I have a similar problem. Sometimes when I get to the car, there is no sound opening from the left front door, but the door opens, as if the door is left open.
Sometimes it doesn't lock on the inner button.
A master relay is broken, look relay sound is not said. But I couldn't understand from the sound frankly.
My remote is already broken.
I was available but I couldn't look at all this
I think door locks need to be overhauled.
08.05.2020 18:51 # 5
yapraklar
unfortunately my fault continues. I'm going to die.
08.05.2020 18:51 # 6
yapraklar
Slm. The doors of my 2010 model Peugeot 206+ are not locked with a remote control or direct key. There is no problem in locking after going for a while, but according to the availability of the parking lot, the vehicle does not only lock in the rear doors or four doors after the location has been changed. Only the tailgate is locked. Masters could not find a solution
I would be glad if you have help with knowledge. Respects.
my fault continues ....
08.05.2020 18:51 # 7
Samet Cetin
Hello, I have the same problem in my car, I'm currently in Çorlu, unfortunately I couldn't find anyone who understands here. If I was in Ankara, my masters would definitely solve it, I will manage it this way until I have a solution like this; remove the battery terminal, wait a little bit, plug it back in, but after a while it becomes passive again. I will write if I find the permanent solution of the problem. Samet Cetin 2014-11-25 09:35:27
08.05.2020 18:51 # 8
muhammed.ceyhan
lock and unlock prolwmi:
Remove the sockets inside the doors of the doors and press the lock button. start from the front doors in order. remove one and try. If there is the same problem, try at the other door. whichever door they lock, there is a problem in the swich of that door. Find the cable that turns on the ceiling lamp. with the control pen in auto electricians. cut that cable. no problem.
