the problem of not eating gas
08.05.2020 18:55 # 1
seydisehirli
good morning friends 307 xt my car does not have gas, the pedal presses the car, there is no problem in gasoline.
08.05.2020 18:55 # 2
serdaralisan
Look at the lpg setting, if there is no problem in me, if my old 206 had the same problem, they said that the gas does not go in normal gas, it does not eat gas, I took it to the place where I got it, and they did not fit with the vehicle, the brain changed, they made a setting after the lpg.
08.05.2020 18:55 # 3
seydisehirli
I do not know where it was attached.
08.05.2020 18:55 # 4
resulacar
I have the same problem with me, but mine does it on gasoline, when I fully increase the gear, there is a shake-up at 4 and 5 at no problem 1-2-3. I use division. Nobody could find it.
08.05.2020 18:55 # 5
sezar206
[QUOTE = resulacar] I have the same problem, but mine does it on gasoline, when I fully increase the gears there is a shake at 4 and 5 at no problem 1-2-3. I'm using split. Nobody could find it. [/ QUOTE] Have you changed the coil and tried it.
08.05.2020 18:55 # 6
seydisehirli
My problem is usually when the car is cold.
08.05.2020 18:55 # 7
muro_60
the gas may pass early when it is cold and this is liquid gas is going to go.
08.05.2020 18:55 # 8
seydisehirli
Just like what you say, brother does not eat gas I made the gas setting last night but nothing changed
08.05.2020 18:55 # 9
muro_60
Check the degree to which the gas is passed. As soon as the heating can be a problem in the regulator, the gas is going to pass over the time.
08.05.2020 18:55 # 10
seydisehirli
When the room is idling at about 600 meters
08.05.2020 18:55 # 11
muro_60
I don't know how bad the weather is there, but you have to go to the veteran and make it 30-35 degrees. If not, the regulator is defective.
08.05.2020 18:55 # 12
seydisehirli
ok brother thanks i will go for this day
