The problem of movement !!
08.05.2020 19:58 # 1
srhtccn
Hello, I have a 2006 model car with 206 1.4 automatic petrol cylinder. When we ride with 4 people while driving, the car hardly falls out of the traction. When the vehicle has a hard time, the temperature hand stops between 90 and 100 and lasts up to 100. I looked at the water of the car, okay, what should I do?
08.05.2020 19:58 # 2
Efe-Pojo
in this normal hot weather
08.05.2020 19:58 # 3
esstel
antifreeze coolant (good quality and blue) and replace pure water, air filter, etc. If the maintenance is complete, you will see a little benefit.
08.05.2020 19:58 # 4
talip206
these are normal values. Especially if the car is full of hot air.
08.05.2020 19:58 # 5
srhtccn
Thanks
08.05.2020 19:58 # 6
Delete
I wish you good holidays, let me share my problem of movement. My car is the Peugeot 206 2004 xline 1.4 petrol. I have never seen the vehicle go up to 90 for 1 year, and even friends were surprised. For the first time yesterday, I gave the vehicle to my brother-in-law, he said that the temperature rose from 70 to red and when I was hot, I opened more than 5 liters of water that had opened up the water tank when I was hot. I looked at the car in the morning, there is no water leakage, etc. But we tried it for 2-3 km. The temperature rises slowly and it is red, the fan turns on. I touched it in a few minutes. Is it a cold thermostat? I think about how I can take it within 52 km of the service. Delete 2016-09-16 08:53:07
08.05.2020 19:58 # 7
Dlkrn_48
Brother, I would like to ask you something. Our temperature indicator (2002 1.4 petrol XR I think) .. I have a white background instrument panel. I thought the first line over 90 was 100 in the temperature display section. When you say the temperature of the vehicle is 100, do you mean the working line over 90 degrees?
08.05.2020 19:58 # 8
error
I saw 98. 99, let's say 100, but the danger is beyond care.
Have a nice holiday.
08.05.2020 19:58 # 9
reality59
I know the times when red is halfway.
Depending on the way you use the tool, the combs of the radiator in your vehicle, the liquid in the radiator, even the type of the radiator (sheet metal, aluminum), the condition of the thermostat, the temperature of the temperature sensor, etc. For some reason, your vehicle's temperature may increase.
