The problem of getting water from the doors. The solution is inside.
08.05.2020 17:31 # 1
My troubled door is the right rear door. I had opened a subject before. There are those who say it is because of it & nbsp; but I couldn't figure it out on my own. The door wick was torn, I glued it beautifully. I looked? It's still getting water. I tampered with the drain valves under the car. I tried to clog? It's still getting water. Even if I said that it takes water, if it rains for 1 day, the floor carpet gets a little wet. Then I wandered between the door and the body by wiping cloth for days. Unfortunately, until we investigate this problem on foreign sites, & nbsp; "Wink" The following photos are excerpts. It does not belong to me. Anyway, my problem was that the nylon thing inside the door was not fully adhered to. As the water came in as it rained, it was giving water over the wick from the bottom. Those with such a problem should open the door and take a look. Maybe my help will touch. Have a nice day.
< img src = "http://www.akustix.de/img/AstraH/clipse-tuer-rechts.JPG" border = "0" />
GökhaN 2013-04-15 09:03:12
08.05.2020 17:31 # 2
There is also something I cannot understand. If that nylon-like thing prevents water from entering, that is, the door gets wet when it rains or when we wash it?
08.05.2020 17:31 # 3
ahmed206
I don't think of water entering the door. How many metal parts in it are oxidized. I think luckily the insulation was made from above
08.05.2020 17:31 # 4
xMEGANx
Not normal. Water channels are clogged or holes are not science, but there is a problem. You should carefully examine the floors after removing them.
08.05.2020 17:31 # 5
ahmed206
Either these door trims are very deceptive. I haven't been able to locate the sound on the tailgate for 2 months. It turns out that it was in such an easy place that the source of the sound. It does not come to my mind to look at the mechanism that opens the door ... So be careful ...
08.05.2020 17:31 # 6
emre_akdag
Insulating nylon does not completely prevent water. Probably deformation of your vehicle door wicks or the glass outer wick. I think take a good look. The purpose of nylon is to prevent dust from entering the vehicle from outside.
08.05.2020 17:31 # 7
giaver
Good day, I am an owner of the 2005 model 407 SW. I have continuous sounds (squeak) from my car's tailgate on the parquet roads (side streets).
08.05.2020 17:31 # 8
pusutr
Slm. It can be from the trunk lock.
08.05.2020 17:31 # 9
giaver
hi pusutr I pulled the trunk lock down a little bit but nothing has changed, but the sw swings open from the glass on the trunk lid, could it be there?
08.05.2020 17:31 # 10
samet206
I have examined the narrated part, but if I think that my car is picking up from the front door, there is a small blow to the taffeta where the mirror is located, the door is getting out of the door, there is no other solution to repair it.
11.02.2021 16:55 # 11
Bynejo
If your vehicle is getting water inside the rear doors, there is a water drain hole in the lower right corner of the left rear door, for example, there is a water drain hole in the lower left corner of the right rear door.These holes are drilled by inserting a screwdriver or a pencil into the holes and the accumulated water starts to flow. ...
30.11.2023 16:21 # 12
black_jeruz
Hello sir, my 307 also gets water from the same place. The second picture is not visible. Are you saying that it gets water from the insulation around the inner door panel?
