THE PROBLEM OF GAS REACTION
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 20:04 # 1
BOZKURT71
hi friends here I want to talk about an application that will save you money. If your vehicle reacts late to gas and then accelerates, remove the oxygen sensor located in the manifold part of the vehicle and if the tip is attached to the particle soot, sand it thoroughly with sandpaper until the metal learns itself. Then, tighten the margins with a lining spray and even soak for 20 minutes. then it will dry soon and install the tool. It will work like a clock. Best regards
08.05.2020 20:04 # 2
dejawu1978
Thank you .... I wish you could explain this in more detail with the pictures.
08.05.2020 20:04 # 3
iammanover
Parts leading from the exhaust end to the previous engine
http://www.parcafilosu.com/resimler/stoksabit/600/98faa62e-4a01-4c69-8367-1b279e9477aa.jpg
http://www.liderparca.com/fb,1088,99,oksijen-sensoru.png
The pictures are representative.
08.05.2020 20:04 # 4
OguzhanKucuk61
[QUOTE = BOZKURT71] hello guys. here I want to talk about an application that will save you money. If your vehicle reacts late to gas and then accelerates, remove the oxygen sensor located in the manifold part of the vehicle and if the tip is attached to the particle soot, sand it thoroughly with sandpaper until the metal learns itself. Then, tighten the margins with a lining spray and even soak for 20 minutes. then it will dry soon and install the tool. It will work like a clock. Yours sincerely [/ QUOTE]
Is this an application that has been tried and achieved by you? There is no delay in my vehicle like that, but it is not like vehicles with gas wires. I was thinking about Sprintbooster, but if it is a really useful application, I would like to try it.
08.05.2020 20:04 # 5
dejawu1978
I wonder if the right part in this video ..? I should not disassemble the wrong part: D and after the shock, would there be a brain-related situation ...?
08.05.2020 20:04 # 6
TooJohn
follow
08.05.2020 20:04 # 7
OguzhanKucuk61
I don't think there will be a problem with the brain, but you can do it by removing the battery terminal to guarantee it.
08.05.2020 20:04 # 8
dejawu1978
follow ...
08.05.2020 20:04 # 9
BOZKURT71
YES, AN APPLICATION THAT I HAVE COMPLETELY OWN. THE VEHICLE WAS MORE FEELING IN DAMAGE GAS REACTION. NOW IT HAS INCREASED THE PROBLEM, AND THE PROBLEM OF NOT EATING GAS IS AVOIDED. IF THE SENSOR IS OXIDATED, THE PROBLEM IS ITS ADMINISTRATIVE.
08.05.2020 20:04 # 10
BOZKURT71
FRIENDS THAT NEED TO REMOVE THE BATTERY POLES HEADS
08.05.2020 20:04 # 11
dejawu1978
Thanks for the sensor, isn't it in the video?
08.05.2020 20:04 # 12
BOZKURT71
TA OWN. IT DOES NOT CREATE A PROBLEM ABOUT THE BRAIN. THE RESULT IS NOT AN ELECTRONIC PROCESS, FULLY MECHANICAL. BEST REGARDS
08.05.2020 20:04 # 13
[QUOTE = BOZKURT71] TA OWN. IT DOES NOT CREATE A PROBLEM ABOUT THE BRAIN. THE RESULT IS NOT AN ELECTRONIC PROCESS, FULLY MECHANICAL. SAYGILARIMLA [/ QUOTE]
It is forbidden to write in capital letters due to the forum rules. We wish you to be more careful from now on.
