THE PROBLEM OF BIDDING AND UNLESS WORK
08.05.2020 17:09 # 1
merkan
Hello friends, As I mentioned in the
member introduction section, I bought a 2004 model 307 XT automatic just 1 week ago. There is Atiker brand lpg in the vehicle at 130.000 km. & Nbsp; I traveled about 1,500 km for a week and had no problems. & Nbsp;
However, while driving yesterday, lpg was over and the car went to gasoline, after a short time the engine started to misfire and to eat gas with gas. started. Then when I pulled aside & nbsp; the tachometer started to play up and down. He gave errors such as "antipollution fault" and "catallttic convecter fault". Connected to a computer in the Private Service. A new coil was brought and tried on the message that there was a burn error in the first cylinder, but the problem continued. My master said there was no injector because both lpg and gasoline gave the same error. The vehicle has been in the service since the morning, when I stopped by in the evening, he said he had cleaned the throttle & checked the lpg connections, but the problem could not be solved. & Nbsp; My master is still trying to solve it. & Nbsp;
If you have any knowledge, I would like your help. Thank you. & Nbsp;
Reviews
& nbsp; & nbsp;
08.05.2020 17:09 # 2
merkan
FRIENDS PROBLEM SOLVED;
The problem was caused by the electrical installation. The electrical system of the vehicle was damaged while the LPG system was being installed. The problem was fixed when the cables were renewed. & Nbsp;
There is no fluctuation in idle at the moment, there is no problem in traction, there is no problem in both lpg and gasoline. I hope I have no other problems.
Greetings ...
08.05.2020 17:09 # 3
nurettin60
hello dude the same happened to me I changed it too but the car is shouting, it does not shoot did you have the same problem
08.05.2020 17:09 # 4
yukselinanir
The same thing happened to me, I went out of the hunters, while I was going to izmir, it turned out to be in my coil, but I made it for 250 TL.
08.05.2020 17:09 # 5
Barut
your eyes are bright.
