THE PROBLEM I LIVE IN LPG
08.05.2020 21:09 # 1
Ayktycdg
Hello friends peguat 306 Xn 1.6 1998 model cloth I have the lpg vehicle I bought the vehicle in 2011 and since then I had a problem in the LPG, I was on the way last year, LPG error was on the way, self-idle adjustment twenty cycles. I reset the LPG last year, I got the last system atiker brand in the 7th month. I have a problem for 3 4 months. It says it does not work properly, I went to the tube setting 4 times last night.
08.05.2020 21:09 # 2
Unfortunately, the teacher does not accept the mistake that most masters in the lpg system do. As you said, if there is no problem in gasoline, there is a high probability of an assembly error in the LPG system. And the spark plugs and coil of the vehicle were never checked. Even though these parts are defective, sometimes you cannot feel them in gasoline. I also checked the throttle cleaning and idle sensor.
08.05.2020 21:09 # 3
Ayktycdg
When I say there is a problem with LPG gas, I brought the car back, spark plugs, injectors, throttle ignition, I checked all of them, even I used it in a gas station, I did not experience any problem for control purposes. it freezes to its old order. What can I do about it? I can't find it anymore.
08.05.2020 21:09 # 4
Karacocuk24
[QUOTE = Ayktycdg] When I say there is a problem with LPG gas, I brought the car back, I used spark plugs, injectors, throttle ignition, I checked all of them, even used it in a gasoline control, I did not experience any distress. After a few days, it is freezing to its old layout. What can I do about it? I can't find it anymore. If I say it's wrong, call the center of the atiker and report your complaint, maybe they might be more relevant
08.05.2020 21:09 # 5
ismailkaya
Some vehicles of the peugeot group do not keep order in the lpg helix 1.4 16 v 90 hp. The reason for this is that the working principle of the engine is completely produced for gasoline. Use a little bit then update the lpg software. If they can ask the master you will update the LPG software if we can update this vehicle while on the road, I would say that if you have a broken air hose in your car, you may encounter such problems if the patch made affects the air flow.
