The piece on the engine that I can't grasp?
08.05.2020 14:04 # 1
IsmailAtes
Hello friends yesterday, when I was looking at the oil of the vehicle, it was a piece that caught my attention. There was a piece that was swinging at the cross of the motor ear next to the catalyst. As an object, I looked at the sensor as a cable and 2 thin pipes. There is room for the other, but there is room for the other, but I did not know what it was not. What is it and how the pipes are connected. Thank you for your attention.
08.05.2020 14:04 # 2
peugeotefe
The suction sensor of interest with the EGR absorbs the treadmill of the turbo with the pressure it receives from the brake vetanaz. peugeotef to 2009-06-23 12:14:25
08.05.2020 14:04 # 3
IsmailAtes
I understand, is that the reaction of this car, whether it's a low reaction or not, is there a connection direction?
08.05.2020 14:04 # 4
hasimayaz
The solenoid valve
08.05.2020 14:04 # 5
IsmailAtes
Thanks for your visuals, brother, number 1 you have shown in the picture, but I couldn't make out the connection type for pipes, I guess pipes 6 and 7 will be connected right?
08.05.2020 14:04 # 6
hasimayaz
[QUOTE = AteSH] Thanks for the visual image, brother brother is the number 1 piece you have shown in the picture, but I couldn't make the connection for the pipes, I guess pipes 6 and 7 will be connected, right? [/ QUOTE]
It is true. You can not install it wrong, Ismail is hard, you need to screw it up.
08.05.2020 14:04 # 7
IsmailAtes
[QUOTE = hasimayaz] [QUOTE = AteSH] Thanks for your image, brother Haim is the number 1 piece you have shown in the picture, but I couldn't make the connection for the pipes, I guess pipes 6 and 7 will be connected, right? [/ QUOTE]
It is true. You can't install it anyway, Ismail is hard. You need to screw it up. [/ QUOTE]
According to the pipes alone, one is already connected, and it is also in reverse connection, because of the way the couplings come. Smile
08.05.2020 14:04 # 8
peugeotefe
you can turn on a malfunction lamp.
08.05.2020 14:04 # 9
SelmanBeber
welcome to master masters
08.05.2020 14:04 # 10
IsmailAtes
I fit the couplings according to the direction of arrival, but the car became very strange, even if in 1st gear, if I press the gas to the end it does not go, it acts like it does not eat gas, but then it gradually takes the gas I gave it, but this time is too long. light turns on and goes off after 3-4 seconds. In this case, I do not want an intervention or would I make any malfunctions?
08.05.2020 14:04 # 11
peugeotefe
Is the lamp on while the vehicle is running?
08.05.2020 14:04 # 12
IsmailAtes
No, it does not light when it is working. It is waiting for 3-4 seconds from the moment I switch on the ignition and goes off.
08.05.2020 14:04 # 13
peugeotefe
It is normal for the ignition to light up.
08.05.2020 14:04 # 14
IsmailAtes
Maybe it was not burning before, maybe it may have caught my new attention.Thank you very much for your attention and help.
08.05.2020 14:04 # 15
peugeotefe
lights up in every vehicle attracted your attention
08.05.2020 14:04 # 16
IsmailAtes
I'll probably pay attention to it from now on.
08.05.2020 14:04 # 17
hasimayaz
burns without starting. 1 sec after starting the starter. then goes out. Ismail is normal. Like every vehicle. I think he hasn't gotten his attention before.
08.05.2020 14:04 # 18
IsmailAtes
Yes, brother, I did it in my other rides today, I did not pay attention to the same.
08.05.2020 14:04 # 19
individual
what is this engine
1.4 or 1.6 mi
petrol or diesel
I wondered
08.05.2020 14:04 # 20
peugeotefe
1.4 HDI
