The performance of my xenon headlights is not good help
08.05.2020 14:07 # 1
MertCakbak
Greetings. My 106 car has Junyan angel and 8k xenon, but it doesn't show the way well. Obviously there is no Xenon performance.
& nbsp;
And my second question is, can I just use the bulbs instead of 6k instead of my 8k? >
Which brand rather than bulbs
& nbsp;
Thank you
08.05.2020 14:07 # 2
You can use it by making 6k, and the product you are using is probably the quality of the product from that face, the quality of the product is lower than 6k.
08.05.2020 14:07 # 3
Murat
My teacher 8000k does not please anybody in terms of opinion. Since those who use this type of light bulb give crystal blue light, when they look from the outside, they use it to look a little more beautiful. 6K gives full white light. You will be more than 8K, but if you wear 5 or 4.3, you will be more satisfied.
08.05.2020 14:07 # 4
MertCakbak
[QUOTE = EmRaH] You can use it by making 6k, probably the product you are using is good, the image quality is lower than that, it gives 6k more efficiency. [/ QUOTE]
& nbsp;
Well, if I only get the bulb 6k and good quality without changing the balance, thank you
08.05.2020 14:07 # 5
When it comes to quality, there is no mtech to those balances.
08.05.2020 14:07 # 6
MertCakbak
I'll have 6k instead of 8k.
08.05.2020 14:07 # 7
the same kind of medicine is between 30-35 TL.
08.05.2020 14:07 # 8
hasimayaz
I think you can not get a pair because of the seasonal conditions. If the lenses of the xenon lenses get a little dirty, the performance decreases excessively.
08.05.2020 14:07 # 9
GokhaN
6000k or 4300k if you can get the best. Plug in the 8000k, see the performance, then see the performance "Smile" all eyes are on you
08.05.2020 14:07 # 10
CIHANGIR_DONMEZ
the same problem was in me, the first one is not illuminating the road better than 6000 k, the second lenses are unqualified junyan as you know, the sense of the headlight of the headlight of the headlight of the headlight of the headlight of the headlight, the position of the light bulb is obtuse, it is tight and deep, sit in the socket, sit tight and sit down gıdıo dagılıo to the stones, pay attention to this very much.
08.05.2020 14:07 # 11
MirakGTI
[QUOTE = GökhaN] 6000k or 4300k if you can get the most beautiful. Plug in the 8000k, see the performance, then see the performance "Smile" all eyes on you
open :))))))))
08.05.2020 14:07 # 12
MertCakbak
Thank you very much for your help, we will change the lenses if I try and get 6k first
& nbsp;
Thanks again
