the performance of my car has dropped, very urgent help |
| 08.05.2020 19:07 | # 1 |
legolas |
vehicle 2004 206 desire teriger maintenance is new but when i get it i noticed that the car has a low perfons and the tachometer rises quickly
| 08.05.2020 19:07 | # 2 |
Efe-Pojo |
If it happened after the timing, the sente setting was wrong, I think such important things should be done in the service. But if the turnover is rising quickly, I don't understand how the performance has fallen.
| 08.05.2020 19:07 | # 3 |
If it happened after the timing, he could not adjust his synthesis. If any, the speed is up and the vehicle is not going, it is the pressure pad.
| 08.05.2020 19:07 | # 4 |
legolas |
It was high after the timing change, but it does not go as before, I do not understand, I do not understand from the cars, I do not trust the masters too.
| 08.05.2020 19:07 | # 5 |
I know that the problem in the lining does not appear all of a sudden, it is a problem that progresses over time, I think take it to the service and have it adjusted. |
| 08.05.2020 19:07 | # 6 |
legolas |
Thank you very much for the information you provided.
| 08.05.2020 19:07 | # 7 |
Efe-Pojo |
[QUOTE = legolas] Thank you very much for the information you provided. [/ QUOTE] Setting back tri can be quite expensive in service but worth it because so-called masters who do not know are including such cars.
