The PArk Bulb is on
08.05.2020 21:08 # 1
Frt-Aydin
Good evening
There is a problem with tell me in my car.
my parking bulbs constantly darken. Made black inside your headlight.
4. We have changed the bulb, but I showed the dureum at the same electrician.
08.05.2020 21:08 # 2
Well, I looked at it while the car is on the load, my brother can give extra voltage when the charger is in motion. You should try quality bulbs.
08.05.2020 21:08 # 3
Frt-Aydin
I installed a different bulb, soner
only the trouble of the parks made me think let me see if I don't have a problem with the bulbs for now, I will listen to your advice.
If you remember, I had a transmission problem. based on this one adjusted the valve. anyway
I went to the oil change last night, the master valves there were very tight, there was a creaking sound at idle
Do you have any settings or anything?
08.05.2020 21:08 # 4
There is valve adjustment, my teacher. Get a good master who knows peugeot.
08.05.2020 21:08 # 5
Frt-Aydin
Thanks my master
08.05.2020 21:08 # 6
In addition, the 16 v engine will not have a valve adjustment. You have to look at the timing sentence setting.
08.05.2020 21:08 # 7
Frt-Aydin
no 8v vehicle but you said well I will have a test check
