The nudge and anti-collision from the engine has been solved!
08.05.2020 17:09 # 1
muro_60
friends, I thought it was in the valve thrust from my engine, and I disassembled myself, I changed two of them. I asked the service, they said valve pushers, they were about 1000 lira. Meanwhile, the anti-collective malfunction caused a rich mixture, I suspect the coil last night and loosened the coil of the coil and suddenly it was cut. I was delighted:) When I pressed the coil, the sound comes loose, the sound is cut off, I immediately removed it, looked at the spark plugs. I extinguished the malfunction lamp and it did not burn. I said if I did not find it, it was 1000 lira.
08.05.2020 17:09 # 2
okan4037
get well :) good to understand from the car :)
08.05.2020 17:09 # 3
muro_60
[QUOTE = okan4037] get well :) good to understand from the car :) [/ QUOTE] & nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; sagolas, if we don't understand it :))
08.05.2020 17:09 # 4
hakan38
Yes, it is very important to understand the same car from the same car. The masters will be able to change the spark plug set to 100 TL for the magnificent island. moreover, when a lpg fault that is not a mastaf is released, the malfunction of the person is broken
08.05.2020 17:09 # 5
muro_60
they said 16 lira for the service, how it was a spark plug.
