The moving vehicle is not engaged in 1st gear ???
08.05.2020 17:24 # 1
ahmet_bjk
Friends moving vehicle is not said to be engaged in 1st gear, do you think this is true?
For example, we slowed down to 10 km / h do you put it in 1st gear or 2nd gear?
& nbsp;
2 If it is thrown, the engine speed can drop to 1000s and it forces the engine, is there any harm to the vehicle?
08.05.2020 17:24 # 2
zgr
In my car, it is already hard to shift to 1st gear at those speeds. Need to force 1 to throw. The vehicle passes and collects easily. I do not know about its accuracy, but I am throwing it to 2. There are master friends who know. we are enlightened.
08.05.2020 17:24 # 3
hLL
[QUOTE = ahmet_bjk] Friends moving vehicle is not said to be engaged in 1st gear, do you think this is correct?
& nbsp;
2 If it is thrown, the engine speed can drop down to 1000s and it forces the engine. Is there any damage to the vehicle?
08.05.2020 17:24 # 4
cerci07
In the 2nd gear, where it is not pulled or where the speed is low, the first gear is thrown.
08.05.2020 17:24 # 5
engin
1 is thrown if the gas-powered late tank is giving or sounds are coming from the engine
08.05.2020 17:24 # 6
_ali_
In such cases, I always use 1 instead of 2nd gear when the engine is cold or uphill, and I also use 1> 3 or 2> 4 depending on the road condition.
08.05.2020 17:24 # 7
xMEGANx
Used to lift the vehicle ONLY AND ONLY in the 1 Gear cars. many people do not know this very rare information. 1. The purpose of the gear is just to lift the vehicle.
08.05.2020 17:24 # 8
CIo
instead of braking all the time while going down the slope, you can throw it down with 1 and motor brake. Gear 1 is not just for lifting. There are some places, the descent is too slow, it is necessary to go very slowly. this is my knowledge. I had asked the master for 22 years.
08.05.2020 17:24 # 9
EnSoNiQ
I do not believe it is to lift the vehicle because the vehicle is on the move while my friend's vehicle is getting up at 2, it vibrates, which causes the wear of the pad.
08.05.2020 17:24 # 10
cerci07
Why is there any harm in a good way? Even the automatic gearshift comes down one by one, why did the people who produced this vehicle forget their details in automatic vtes?
08.05.2020 17:24 # 11
mistik
If the 2nd gear says so much and starts to vibrate, it is thrown to 1, this is what should be thrown at the place where it is difficult when going uphill.
08.05.2020 17:24 # 12
volkanC2
Of course, it is thrown or I throw it to 1 and when I throw it to 2, the car says, `` No, you should throw it in aga 1 ''. Big smile
08.05.2020 17:24 # 13
plawert
The 1st gear is the vehicle's take-off gear, unless the vehicle is used in 1st gear unless it is in a difficult situation, even the pattern will go up immediately and the vehicle wants gear increase so the 1st gear is the starting gear of the vehicle.
08.05.2020 17:24 # 14
blinddark
[QUOTE = xMEGANx] 1 Gear Cars ONLY AND ONLY used to lift the vehicle. many people do not know this very rare information. 1. This is the purpose of the gear only to lift the vehicle. [/ QUOTE]
If you do not use a truck or bus, use the first gear only for take-off.
08.05.2020 17:24 # 15
AydinBeyol
I use 1st gear up to 15 km. The engine has difficulty when it is 2 at 10. I have not seen a problem so far.
08.05.2020 17:24 # 16
ahmetismet
What will you do when you don't pull on the slope? Even if it's -1 Dead
08.05.2020 17:24 # 17
Burak
Master has nothing to do with the 1st gear lifting the vehicle, if it does not take over, you will get wherever the car is 1.
08.05.2020 17:24 # 18
& nbsp;
2 If it is thrown, the engine speed can drop to 1000s and it forces the engine. Is there any harm to the vehicle? In this case, it is necessary to either slow down and throw it to 1 or continue from 2. If we were on a straight road and faced with this situation, I would continue from 2. There is no rule that 1 is not allowed, nor is there a rule not to continue from 2. I do not think that both situations will cause harm.
08.05.2020 17:24 # 19
tellotello
No matter how hard I am already downhill, the vehicle does not move easily & nbsp; 1, but I do not have anything to do if I want to get the speed of the car while going uphill. nevertheless, I would make the car almost stop as I climb uphill so that I would not have a hard time, I would take it to 1, and I would prefer to continue by stopping myself from the engine brake (I will not shake the vehicle). I always try to throw it to 2 as soon as possible on the straight road, and it already states itself in the vehicle. I think that it is necessary to behave completely according to the road and traffic. We had to be kind to the gear lever taught in the course & nbsp; "Smile".
08.05.2020 17:24 # 20
Aziz
Friends have been an interesting environment :) It is discarded according to its speed and speed. years' print lining monster speaks: D
