The moment I hit the 406 drain stops
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:34 # 1
salih erhan
slm & nbsp; everyone me 2000 model 406 when I want to stop while going on the road when I press the drain pedal stop & nbsp; We have connected the computer, the relay can be from the sensor, but the sensor looks solid, it looks like it is doing the same problem in LPG and lpg does it.
08.05.2020 16:34 # 2
Fatih Ceyhan
Put your abivity in vain and start the car, see if I will run idle & nbsp;
08.05.2020 16:34 # 3
salih erhan
works at idle but shakes idle 800 to 600
08.05.2020 16:34 # 4
yavuz25
spark plug and ignition installation was checked
08.05.2020 16:34 # 5
There may be a few reasons. Is the engine malfunction light on your vehicle?
08.05.2020 16:34 # 6
KenBlockJR
clear throttle
08.05.2020 16:34 # 7
Kemanyak
Oxygen sensor should be checked. Throat butterfly should be cleaned. Check if there is any crack etc. malfunction in manifold. & nbsp; If gas is not eating either, the coils and spark plugs should be checked.
08.05.2020 16:34 # 8
djchaos
throttle, air filter, if the vehicle is in the tube, gas pump, connect your car to the computer, it is very likely that the lpg problem is drowning at the first departures, I think it is rocking in the rolent, the idling of the vehicle is normal between 900 and 1000 but if it drops below 800, there is a problem in rolent, I hope there is a problem in the brain of the vehicle. this is unlikely. djchaos 2012-02-08 00:54:00
08.05.2020 16:34 # 9
salih erhan
we looked yesterday, there is a crack in the box of the bob, the ignition is not complete, said the master, let's see if I can go tomorrow, try it
