It is missing from the heater core. The second option is, there are orings, in the part where the heater core is leaking from the middle into the vehicle. It happened to me in my car too. Honeycomb was intact. He was kidnapping from the orings. A piece of plastic called oring is 2-3 pounds. It takes a little bit of crafting. I gave 80 pounds of labor. If Honeycomb prices change, it is yours. Kale brand has around 80 100 pounds. If you say I have no problems, I know the room is double, 180 200, I know. I also advise you to dry the vehicle. Because there is a very dirty material under the carpet, take it out without drying out and dry it in the sun in 2 days. To remove the carpet when you remove that piece, shake half a kilo of rice, leave it under the carpet for 2 days, pull all the moisture, then pull it with a broom and let the piece dry. Good luck with.
