the mat below does not dry .. !!
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 19:03 # 1
byderebey
friends before my car was wet under the mop, radiator was built, there was no problem in it but still it did not dry .. i am sure that it does not come from the heater honey. It stops .. I just published a newspaper, I don't know if it will work, but is it war with an idea?
08.05.2020 19:03 # 2
albayman
There are insulating cups under the mop, they are in the pool. It is hard before the water in the pool and scouts dry out. It must be inserted and dried. Do a water test when ready, see the water alium from right to left. It happened to me.
08.05.2020 19:03 # 3
samet206
It dries up over time, it is normal to dry, it takes time if you are sure that the problem is resolved.
08.05.2020 19:03 # 4
Faruk
[QUOTE = byderebey] friends before my car was wet under the mop of the radiator radiator was made it did not have any problem but it still did not dry .. i am sure that it does not come out of the radiator honeycomb is full base wet .. it is such a long time to dry it or if there is another problem, i wonder if it takes water from the bottom .. The middle of the mop is impossible. I just spread the newspaper, I don't know if it will work, but is it an idea war? [/ QUOTE]
Get well soon.
In me, the front was taking the original glass, the brake pedal was dripping, the lake was falling in the weather.
Put a napkin on the brake pedal in the rain.
There is a dryer in auto hairdressers as wetness, they release the handle from the window of the vehicle and blow hot air for 1-2 hours.
The exact solution for 50-100 because you will get it in one place.
I do not give 50-100, just spread the newspaper under the mat like me, refresh it as it gets wet.
When using the vehicle, leave the mat on the pavement open to the sunshine bio.
I dried it this way, but it wasn't full winter.
08.05.2020 19:03 # 5
Mesut48
Is there any shortage in the spare water container? Replace the heating core gaskets called karering, if any ,
I am trying to dry it with a newspaper.
08.05.2020 19:03 # 6
byderebey
There is no drop, I try to dry it by putting a newspaper.
08.05.2020 19:03 # 7
KILIC
In my 207, my soil was constantly in the water in the rainy weather. I did not go to the service master, I searched from the net, I found that the front wipers in the front were blocked.
08.05.2020 19:03 # 8
faldov
If there is no leakage, it is caused by cooling water. We know antifreeze is a liquid. Do not come out easily. Spread a newspaper under the mat and renew it every 2-3 days. Open the doors on a sunny day towards summer and let them dry. This way your problem will be solved.
08.05.2020 19:03 # 9
byderebey
[QUOTE = faldov] If there is no leak it is caused by the coolant. We know antifreeze is a liquid. Do not come out easily. Spread a newspaper under the mat and renew it every 2-3 days. Open the doors on a sunny day towards summer and let them dry. This way your problem will be solved. [/ QUOTE]
I am doing it now, there is nothing to do .. thank you brother ..
