THE LPG INDICATOR IS DECREASING WHEN LPG.
08.05.2020 17:20 # 1
iozbudak
307 SW PREMIUM 2006,
I HAVE LPG IN THE VEHICLE. WHEN GASOLINE HALF TANKS ARE AND THE LPG IS ON THE GO, THE GASOLINE INDICATOR IS SPENDING AS GASOLINE AND IT IS DOWN TO RED. THEN ABS, ETS VS LIGHTS BEGIN ON. Even if you stop and run it again, the hand does not rise. BUY 10 TL GASOLINE, İBRE IS COMING TO THE WHERE IT SHOWS IMMEDIATELY. SEMI HALF WILL BE INSTALLED. BRIEFLY UNDERSTAND. THE GASOLINE IS STOPPING AS IT HAS NOT REALLY EXPENSED GASOLINE WHEN HALF STORAGE IS BELOW DOWN. THE QUESTION IS.
& nbsp; HOW CAN I REPLACE THE NEEDLE WITHOUT GASING WHEN LPG IS USED WHEN GASOLINE IS AVAILABLE, IF GASOLINE IS NOT SPENDED. IF I STOP AND RUN IT BACK, THE IRON DOES NOT RISE. DO I HAVE TO OBTAIN GASOLINE TO UPGRADE THE NEEDLE ?. OR IS THERE A FORMULA TO TAKE THE INDICATOR TO THE REAL INDICATOR LINE WITHOUT GASOLINE? THANK YOU NOW FOR ANSWERS.
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
Reviews
08.05.2020 17:20 # 2
Serkan
When the vehicle is refueled, the buoy measures the amount of fuel, and then the indicator starts to decrease according to the km you traveled, that is, the vehicle thinks that it is going in petrol, the float measures the fuel again and the indicator returns to normal in your next gasoline purchase. The system is the same for all peugeot.
The first solution is where a device called psa module is installed where the LPG is installed, and the float measures the current fuel every time the vehicle is stopped and restarted, but if you go 400 km without stopping the vehicle, the fuel gauge drops again and rises when you stop and start it. .
The second solution is cheap, some of the details need to be dealt with in the link below.
http://forum.peugeotturkey.com/forum_posts.asp?TID=13780&title=lpg-de-benzin-ibresi- di-cheap-to-problem solutions Reviews
08.05.2020 17:20 # 3
muhammedyksl
Brother, don't worry, I have the same trouble, you are going to the mechanic, saying nothing will shake and shaking, I have no work to stop, but I am annoyed as soon as I give warning that there is no gas, but if you find a method, let me know a method
08.05.2020 17:20 # 4
ersin025
For this, there is a remedy with a very simple system, or a module for about 100 TL is installed, doing the same work with the two, but the petrol indicator drops when it goes, the system that is installed is just a solution for you to reset the system by yourself or when you turn the ignition off and on, it will reset itself, but I think there is no need for them especially If the gasoline is over half a tank, it resets itself or if you get 20 tl of petrol while you are getting a little LPG, it is a normal replacement. The only problem it creates is that I need to ignore it as well.
