The lower part of the 206 gti driver's seat got wet :(
08.05.2020 17:47 # 1
OguzOzaydin
In the morning I got into the car and looked at the place where we stepped. It was wet.
08.05.2020 17:47 # 2
samet206
Heater honeycomb burst, hojam, look at the radiator water. What I mean is that if there is no external factor, the main reason for the mat to get wet is the burst of the honeycombs.
08.05.2020 17:47 # 3
soner09
it is absolutely correct or is missing
08.05.2020 17:47 # 4
E.B
As far as I can see from the pictures, your car is sunroof
If it was raining at night, it might have been sunroof. I had 206 sunroof on me.
08.05.2020 17:47 # 5
OguzOzaydin
No rain did not rain. The bottom part of the driver's seat has already started to be on one side. It is not only wet in the complex. Only a certain part of it. What is the solution?
08.05.2020 17:47 # 6
soner09
Could you find the place where the water fled? ceksen
08.05.2020 17:47 # 7
OguzOzaydin
It happens where I step down, there is absolutely no wetness at the edges. When I pull the car to the flat place, it does not get wet.
08.05.2020 17:47 # 8
samet206
[QUOTE = OguzOzaydin] is where I stand, there is absolutely no wetness at the edges. I don't get wet when I pull the car flat. I find it slightly wet. I find it wet.
If the problem is like I said, if there is a water leak, there is a repair, but I do not recommend it. If you want to install a honeycomb, it has a price of 400 - 500 TL, original honeycomb + workmanship. If you wear an imported honeycomb, I remember that the imported honeycomb is 100 TL. Workmanship at 100 TL, you can handle 200 TL or something. If the problem is with honeycombs, the solution is like this.
08.05.2020 17:47 # 9
OguzOzaydin
I hope there will be no other problems .. let's see what they say. So does he have a situation like harming anything?
08.05.2020 17:47 # 10
samet206
[QUOTE = OguzOzaydin] I hope there will be no other problems ... let's see what they say. So is there any situation like harming anything now? [/ QUOTE]
Because it is summer, the problem is a little less, it happened to me in winter, it was worse, but even if it is summer, it can cause rotting because it gives continuous wetness to the floor of the vehicle and of course, your radiator water is decreasing.
samet206 2013-07-15 13:00:35
08.05.2020 17:47 # 11
ErolSs
Brother I blew it personally: D I know:) D heating pad under breast
I gave 180 TL to the original honeycombs, I gave 225 TL to the chest disassembly, the same master did it all, it took 2 days.
08.05.2020 17:47 # 12
scorpions_64
I had the same problem as well, after putting the antifreeze on the front part of the driver's seat there was mild wetting, the problem is at the top of the gas pedal (just below the panel where the air conditioner control is, there is nothing in the photo, but you will probably see that place) there is something like a fabrication supplement. the ratio does not have bolts. I bought 2 bolts with nuts and tightened that additional connection and the problem was solved.
08.05.2020 17:47 # 13
umut_25
If trouble is honeycomb, you will already see imbalances in temperature. The same thing happened to me. He was leaking from the gas pedal. I gave a money between 300-350 TL, the entire front console was removed and replaced. Now there is no problem. Get well soon
08.05.2020 17:47 # 14
snmertas
Hello friends, I have the same problem in my pejo at 206. they say the front panel is painful. Can I open it up or I am afraid that I will be a hahalu lady with a bolt and thank you
08.05.2020 17:47 # 15
zerzevat
In many places in the forum, the repair is mentioned without dismantling the console? Is this not possible because the 206 is a bit smaller? will the console be removed?
08.05.2020 17:47 # 16
snmertas
He said that all the masters you have spoken so far must be dismantled.
08.05.2020 17:47 # 17
samet206
[QUOTE = snmertas] all the masters you have spoken so far must be removed. [/ QUOTE]
For the change, it is possible to disassemble it as much as it seems to be disassembled, but most masters do not know this or do not come to work.
08.05.2020 17:47 # 18
yavuz_0051
If it is not honeycomb, do not disassemble it. You can even do it yourself if it is missing from the orling. I did it myself.
08.05.2020 17:47 # 19
zerzevat
Is it possible to find square rings on the market? my hand holds the screwdriver.
I also wonder my car does not miss constantly. only when the heater knob is turned to warm position - it misses in winter. IS THERE A HEATER TAP FOR THESE VEHICLES? IS YOKSA PETEK CONTINUOUSLY HOT AND HOT AIR ADJUSTMENT SET WITH THE COVER AS IS IN RENAULT?
08.05.2020 17:47 # 20
bysarsinti
I changed it until 1 week ago, console console was not removed. 60 tl honeycomb, 50 lira workmanship and 110 tl. The complete disassembly of the console will cause trouble in the future. The masters can not wear as they disassemble, they do not necessarily fit incorrectly or sit properly. I definitely recommend that you do not disassemble the console ...
Page : / 2
