The letter K is lit on my dashboard EMERGENCY AID |
| 08.05.2020 19:35 | # 1 |
Firstly, when I start the car a little, it will move a little and clutch and stop when the gear shifts. |
| 08.05.2020 19:35 | # 2 |
My wind is on as color? It is not exactly K, but if I think there is something like the letter K in the engine malfunction lamp in my vehicle, the malfunction lamp you mentioned is the light that turns on when the ignition is turned on with the handbrake lights without starting the car, and goes out after the car starts. unfortunately. |
| 08.05.2020 19:35 | # 3 |
| 08.05.2020 19:35 | # 4 |
mimit |
the snow lamp is pretty funny, the signs on the car dashboard are considered universal, and since this is not sparse for the universal language, the letter K does not mean snow, the snow symbol is something different, the burning light engine malfunction lamp lights when there is any problem in the engine, so it is the direct We can not say that it is burning for whatever reason, whatever the troubles in the vehicle are, comments can be made accordingly. your problem may be one or more of the reasons ranging from the ignition system to the idle and pressure sensors, there may even be an injector blockage, the vehicle must be connected to the computer in the service and the error code must be read for an incision result. this symbol is the malfunction lamp, it was like this in many vehicles of 2000 model and before, then it changed a little more. ![]() |
| 08.05.2020 19:35 | # 5 |
There is a k letter in the engine sign, there may be a catalyst malfunction.
| 08.05.2020 19:35 | # 6 |
It would be better if you find the user manual and look from there.
| 08.05.2020 19:35 | # 7 |
I understood the event very differently :) I opened a title on this subject. I started to burn in 206. it goes out. After a while it burns again. as trouble in the vehicle; The contact sometimes just clicks on the sound. He never goes to the starter event when he does that. sometimes it works without any trouble. Do you have any idea what my problem might be?
| 08.05.2020 19:35 | # 8 |
looks like the engine malfunction lamp. most likely it.
| 08.05.2020 19:35 | # 9 |
Ignition thermal is out of yours
| 08.05.2020 19:35 | # 10 |
[QUOTE = guest] I understood the event very differently :) I opened a title on this subject. I started to burn in 206. it goes out. After a while it burns again. as trouble in the vehicle; The contact sometimes just clicks on the sound. He never goes to the starter event when he does that. sometimes it works without any trouble. Do you have any idea what my problem might be? [/ QUOTE] I think the contact is dead thermal
| 22.02.2022 13:54 | # 11 |
The fault light has been lit. It has been recorded in the brain of the vehicle. You can connect it with obd or pc and see the line.
