The interior of the vehicle smells of exhaust when the vehicle is running.
08.05.2020 18:49 # 1
smiley
Hello friends,
I have a 2001 model quicksilver. The vehicle is at 192 thousand km.
When I get out of the car after using the car, I get a little bit of exhaust smell.
When I showed it to the master, he said the car was leaking oil, and the oil dripping into the exhaust pipe caused this odor. I replaced the axle seal for oil leakage and fixed the seals, but the smell still continues. I wonder what the problem might be.
As for my 2nd question; Somebody show me in the picture for the sake of Allah, where the wiper water in these vehicles is filled :) When I open the hood, there is a water tank in front of the engine where I will fill the engine water. I'll be crazy :)) Or is the tank that I know as engine water actually the wiper water tank, if so, the worse vehicle can be dehydrated. Confused
My last question is that the vehicle shifts into reverse and 5th gear, what could be the reason.
Do not look at the imperfection of my ignorance
smiley 2014-09-30 20:20:06
08.05.2020 18:49 # 2
jack67
I say have the exhaust manidold checked.I heard it smell when it cracked
08.05.2020 18:49 # 3
smiley
Thank you so much. I will consider your suggestion. Does anyone know about my other questions?
08.05.2020 18:49 # 4
smiley
Gncl
08.05.2020 18:49 # 5
peugeotefe
The 5th gear and reverse gear is related to the gearbox oil
08.05.2020 18:49 # 6
smiley
Thank you very much Efe Usta has been a detailed photo.
The interesting thing is that I don't have pipes to put the wiper water in the picture Confused
If I come to the other subject, I just changed the gearbox oil, but what else could be the oil?
08.05.2020 18:49 # 7
peugeotefe
If your vehicle does not have that pipe, they canceled it.
We need to see the vehicle to give a clear information about the transmission
08.05.2020 18:49 # 8
smiley
Come on :) Why would a person cancel the squeegee water tank :))
Thank you very much for the information you provided.
08.05.2020 18:49 # 9
pusutr
That blue capped pipe is a piece of about 17 cm. A removable piece. I think it was removed. Is the wiper water tank canceled, but unfortunately, it is a life saver on the long road.
08.05.2020 18:49 # 10
smiley
[QUOTE = pusutr] That blue capped pipe is a piece of about 17 cm. A removable piece. I think it was removed. Is the wiper water tank canceled, but unfortunately, it is a life saver on the long road.
You said very right. I agree with the end :)
