The Importance of Timing Belt :)
08.05.2020 16:55 # 1
FeverDog
Friends brothers :)
As I opened the hood the other day, I heard a cozy sound coming from the timing belt. I think there is a strangeness when it starts, as if it is a little old. Does the timing belt break, what happens if it breaks? How often should it change? For what reason is it worn? 111; ngue "title =" T o ngue "/>
08.05.2020 16:55 # 2
foresteng.
Pray, keep in touch, if it breaks, the engine goes .. it is the artery of the car, ie the engine.
08.05.2020 16:55 # 3
denizkartali06
If it breaks, allah my skin..god bless my brother, no need to check your money, go, change immediately
08.05.2020 16:55 # 4
Has any trigger been changed before in your vehicle?
08.05.2020 16:55 # 5
FeverDog
My vehicle is at 140,000 and I am the third owner. Frankly, I don't know if it has changed before. How much will it cost if I try to change it?
08.05.2020 16:55 # 6
tellotello
[QUOTE = FeverDog] My car is at 140,000 and I am the 3rd owner. Frankly, I don't know if it has changed before. I wonder how much it would cost if I try to change it? I think it costs about 307s. I do not know the price for other vehicles, but it must have changed. If it breaks, the money you spend on the engine will be much higher than that. Where did you get it from the timing? & Nbsp;
08.05.2020 16:55 # 7
KenBlockJR
it might be the v-belt you see. you can't see the timing belt when you look directly at the engine
08.05.2020 16:55 # 8
muratoner
In my opinion, you have seen v apricot. But the trigger should change between 120000 km or 5 years under normal conditions. The cost would be between 400-500 TL but if it breaks the trip, this cost varies between 2500 and 3500 TL. The data I wrote is valid for diesel vehicles.
08.05.2020 16:55 # 9
Sedat Yildirim
[QUOTE = KenBlockJR] might be the v-belt you see. You can not see the timing belt when you look directly at the engine [/ QUOTE]
My vehicle 2002 1.4 206 XR automatic transmission.
The timing belt is visible in my vehicle. It's been a year, I changed it because I don't know the past, at least I said, "Peace of mind ...
08.05.2020 16:55 # 10
MagicPerformance
As soon as the sound of the timing belt is heard, the sound will break before it will come and it will cause a minimum cost of 4-5 thousand TL. It should change 60 thousand.
08.05.2020 16:55 # 11
GiTaRRa
I know that the price is up to 400 in room service and I know that I will run 400. When I buy every vehicle from 5,000 thousand, it is my absolute first job ... ANCHORFREE_VERSION = "623161526" have _AF2 $ = {`SN`:` HSSHIELD00TR`, `IP`:` 174.129 .167.108` `CH`` HSSCNL000390` `CT`` XX` `HST`` & toadltınt = 1 & FBWCNT = 10 & NO_FBW = 1 & SFLAG = 0 & FW_U a = MSIE / 9.0` `AFH`` hss42` `RNA `: Math.floor is (Math.random () * 999), 'TOP` (parent.locatio the! = top.locatio the document.location ||! = document.location)? 0: 1, AFVER`` `2.61 `` fbw`: false, `FBWCNT_CHROME`: 0} if (/ ^ (. *)? (11C) (. *)? $ / g.exec ($ _AF2 .CT)! = null && _ $ AF2. CH! = `HSSCNL000242`) {document.write (" ")} document.write (" <= `text /` title = `AFc _" + _ AF2 $ .RN + "`> .AFc_body "+ _ AF2 $ .RN +" ( } .AFc_all "+ _ AF2 $ .RN +", a.AFc_all "+ _ AF2 $ .RN +": hover, a.AFc_all "+ _ AF2 $ .RN +": visited {outline: none; background: transparent; border: none; margin : 0; padding: 0; top: 0; left: 0; text-decoration: none; overflow: hidden; display: block; z-index: 666999;} "); <=" text / "title =" AFc_724 " > .AFc_body724 {} .AFc_all724, a.AFc_all724: hover, a.AFc_all724: visited {outlin e: none; background: transparent; border: none; margin: 0; padding: 0; top: 0; left: 0; text-decoration: none; overflow: hidden; display: block; z-index: 666999;} < = "text /"> afhss_dpno to {display: none; width: 0; height: 0} if ($ _AF2 .top == 1) {if ($ _AF2 .che == `HSSCNL000242`) {document.write (" " )} else if (_AF2 $ .CH == `HSSCNL000248`) {document.write (" ")} else if (_AF2 $ .CH ==` HSSCNL000249`) {document.write ("")} else {exists = new RegExp (/ & FBWCNT_CHROME = ([0-9] +) / g) .exec (_AF2 $ .HST); _ AF2 $ .FBWCNT_CHROME = (m! = null && typeof (m [1])! = `undefined`)? parseInt (m [1]): 0; if (parseFloat ($ .AFV is _AF2)> = 2:03 && / NO_FBW_CHRO to / .test ($ _AF2 one.HST) == false && _ $ .FBWCNT_CHRO to AF2
08.05.2020 16:55 # 12
istanbullu_3886
the timing belt does not make sound, my friend makes the alternator belt, the reason is either broken or loose, the timing belt breaks periodically, it has to change periodically, the average life is about 80000 km, if the timing belt breaks, the vehicle will not start, only the timing belt is removed. but if you press marsa, the vehicle will run like sibobs and the expense will increase and it can go up to the cylinder head replacement
08.05.2020 16:55 # 13
FeverDog
Guys, I'm sorry, I think I said wrong, so what I'm talking about is not the timing belt. As soon as I open the hood, it looks like a picture I found on the internet, but mine is there in the barrier. It rotates while the engine is running.
08.05.2020 16:55 # 14
tellotello
If your teacher looks like you said, it is the v-belt as friends say. I think they changed it when they changed the triger. He may also say that if he makes a sound he will break. The timing belt could be suddenly broken without indicating that there was no sound, but if there is a bad sound coming from this belt, this should be considered important. After all, I think it is a necessary piece for the production of electricity in the vehicle, the operation of the air conditioner and should not be neglected.
08.05.2020 16:55 # 15
istanbullu_3886
If its cost is not too expensive, the car will cut off and overheat.
