The ignition does not work
08.05.2020 21:27 # 1
Aykut 28
Selamin aleyküm friends
I have a Peugeot 206 feline car
When I was installing a headlamp on my vehicle, my spark came out and I checked the headlamp cutout electric cut fuse and the fuse was blown out of the fuse, and again the headlamp, my spark and smoke came out, this time all the car's gone
At the moment, when I turn the ignition on my car, there is no light on the indicator, the indicator does not work, the marsa is pressing, there is no teak sound, no electricity goes
But the headlights tape recorders are on fire
I expect the help of friends who are familiar with the subject. CrySmile
08.05.2020 21:27 # 2
ismailkaya
Did you check the fuse boxes in the engine?
08.05.2020 21:27 # 3
Aykut 28
Yes, I checked the fuses under the steering wheel in the couriers next to this engine, no problem.
08.05.2020 21:27 # 4
ismailkaya
Are there large fuses under the fuses in the engine? I have in my car 70 amps 50 amps etc. Is it available in your car that fuses
08.05.2020 21:27 # 5
Aykut 28
Hodja, when I looked at it, I couldn't see it, there is no bigger 20 or 30 bigger insurance.
08.05.2020 21:27 # 6
short circuit bro I hope that even if it looks like it is not burned, it will not be visible without disassembling. After the vehicle, something was done that would affect the American park sound system or electrical system.
08.05.2020 21:27 # 7
Aykut 28
A single one that was added later, this led is not war burned
08.05.2020 21:27 # 8
As our friends say, first check the main fuses. remove the socket of the ceiling lamp. where was the electricity of the LEDs under the foot? I recommend making a separate fuse in these types of transactions.
08.05.2020 21:27 # 9
Aykut 28
As you said, I checked all the fuses that appeared, no problem.
I bought it from the ceiling lamp for the underfoot led 1 year ago it was no problem yesterday evening when the ceiling lamp was changing, my spark came out, there was smoke, then the electricity went away
The windows do not work, there is no electricity to the contact, no mars
But the headlight lock lights up
08.05.2020 21:27 # 10
ismailkaya
Do you know what to do? Follow the battery + tip. Depending on where it is connected to the fuse box, it must be under the ground.
08.05.2020 21:27 # 11
the problem seems to be obeyed by my teacher
08.05.2020 21:27 # 12
Aykut 28
I have followed the plus cable and look there and there is no master there, if the car will work, if the car is not a problem, I can get it left.
08.05.2020 21:27 # 13
Aykut 28
Thank you, the electrician came to obedience
The surplus pole found in the battery made an open cable connection to one of the fuse. When I connected that cable, the car is not working.
Monday, I got the electronics shop
Thanks for your help
14.02.2021 20:13 # 14
aliosmanis
Aykut sister
I also had a problem with this message. how did you solve this job
14.02.2021 20:27 # 15
Aykut 28
Get well soon bro, if you tell me exactly how the problem occurred, I will be of more help to you.
14.02.2021 20:35 # 16
aliosmanis
If my brother is available, I will call you if my number xxxx xxx xx xx sends a call
