THE HYDRAULIC STEERING IS DISABLED
08.05.2020 16:52 # 1
wolf72
Hello friends, I read the air conditioner problems and cd problems. If I think we all have the same problem, the air conditioner works a little in me, then it is silent then it works again, it is silent and it is just doing it in cooling. I wouldn't get caught, 1 month ago, I took the rot balancer for the rot balancing setting for the long road in the summer, he said to me the left and right rods, the right left rot head and the right left z rods will change, of course I changed it. hydraulically disengaged and when the car stops, you start to turn the steering wheel by force, so it happens 2 times, the interesting thing is that the air conditioner is working, I turned it off in the heat, for now, no problem but for the weekend I will take it to the master, the long way is the same in this bend I would be glad if it causes the problem, if there are other friends who have this problem, I would be glad if this solution is shared.
08.05.2020 16:52 # 2
toga406
I have no definite knowledge of the past, but it looks like an electrical problem. The air conditioner draws a lot of electricity. If the hydraulic system cannot get the electricity it needs to take, this may be the problem.
08.05.2020 16:52 # 3
berk2309
mine is like a pile when the air conditioner is on & nbsp; i guess for this electro servo & nbsp; i guess the electri is not enough when i have the air, the rim, how many rooms in 307 original 15 i have 16 i can be stiff in it, thin cheek tire with & nbsp;
08.05.2020 16:52 # 4
wolf72
I changed the air conditioning problem today, I changed the resistance resistance to 140 TL, we got tawn at 30 and master craftsmanship (now I will use it for a bit, I am commenting again) it is not deactivated, but the hardening of the steering wheel has not passed, when I stop and restart the car, this hardness in the steering wheel instantly passes, in short, 5km on the road 4 I had to stop and run it again, this week I will write the result I will go to the master in the steering wheel, but I would be glad if someone who shares it shares an idea
08.05.2020 16:52 # 5
wolf72
I have tires written in the booklet 205 -16, but this is the first time this week, hardening, everywhere in Ankara is not so bad even in countries that go into war, they melt old asphalt and use it again, and whatever they use, when the 2 trucks pass, the roads are bombed, we are waiting in front of the masters of the services, asphalt is melting at 30 degrees, but the roads do not melt in the Arab countries beyond 46 degrees 50 degrees, even the road of the car is smarter than us. roads that are not bombarded:) & nbsp;
08.05.2020 16:52 # 6
mabolla
hello my friend, your problem is probably related to the steering pump, if there is oil accumulation under the fuses, it means that the steering pump is not doing its job. I already had a chronic problem in these vehicles. It didn't work, there is a card inside the pump, something like an electronic circuit has changed it. And now it has been smooth even now it was softer than my steering wheel. But it is useful to find a good electric master for this job. then you probably save the tip. get past
08.05.2020 16:52 # 7
If the steering wheel suddenly goes on, it may be in the dynamo. The tachometer was first detected, then all the fault lights were illuminated, and finally the steering was canceled. I took the vehicle with the tractor, they said to the service, the problem was the dynamo. After that, there was no problem. But I looked, I sold the car, other problems, I sold the car with anger and then I regretted it.
08.05.2020 16:52 # 8
wolf72
[QUOTE = mabolla] hello my friend, your problem is most likely related to the steering pump, if there is oil accumulation under the fuses, it means the steering pump is not doing its job. I already have a chronic problem in these vehicles. My master said he could do it, but it didn't, he also has a card inside the pump, something like an electronic circuit has changed it. And now it has been smooth even now, my steering wheel is better. But it is useful to find a good electric master for this job. If you get it, maybe you can get a solution that can be solved from the insurance so you will save the tip. Get back
my friend the air conditioner master said probably from the steering pump There was oil inside the fuse when it took out the fuses, there is no information if I guess about being repaired because it worked in the service directly, change directly He said if he was pumped, I will be glad if you give your phone if he is in the mainland, I will take him to the master tomorrow morning, but at least it will be useful to go to the lesson if the pump will not be repaired and the room will change. Thanks in advance for that.
08.05.2020 16:52 # 9
mabolla
ok, we were in the same situation with you, my master is a competent master, he can do the repair, but his card has changed since mine has no repairable. even tomorrow we will go and attach the cruise control. As I am in the Batman, as I am in the Batman, the master is also here, so it does not work well, but I think I can help you to know more about the situation in this way. I hope you can handle it easily.
08.05.2020 16:52 # 10
wolf72
thank you you have been very helpful, I hope you just change the card like you & nbsp; or it is a simple mistake as you said, I will write clearly what was done when the problem is solved here, thank you again
08.05.2020 16:52 # 11
mabolla
I hope hallolour or you can take it off and put it on, I guess you can handle around 400 with workmanship.
08.05.2020 16:52 # 12
wolf72
your master was a little more master than ours :), he said that the piece should be changed like the service, they said 500 tl to come out on the mainland I got the original through familiar 2 zero & nbsp; someone who has a steering pump got an original in the industry, thanks to the acquaintance of the original industry, I bought 700 for the sub-industry and gave it a price of 500 TL, but ultimately both I and myself then there is a family of people who will use another person as a result, so I used my idea since the original, in short, 700 TL is 1 liter of oil and 30 TL and 150 TL workmanship has been settled to 880 TL, the problem is gone but some steering is hard & nbsp;
08.05.2020 16:52 # 13
modiemlak
I had the steering stiffener too. The steering card was burnt repaired.
08.05.2020 16:52 # 14
Cemm
brothers good evening everyone had the problem of hardening on the steering wheel before it was done in the electrician, then i went to the industry for the temperature problem on April 4, the sender changed, the fan did not turn on, the electrician's apprentice put the sender, and so on after leaving the industry & nbsp; my speedometer was like a cycle at a time when the car dropped to 0 then it got back and the strangeness started there Anyway on the 3rd day my steering pump got stiff again it was like the black steering wheel you know tomorrow I will go again this time I will not make it apprentice who knows what tied where & nbsp; & nbsp; I started the car, I informed him that he could not come home I burned a cigarette while the engine was running & nbsp; the pump started, our famous voice came, oh I said okay and I started driving home for about 3 km & nbsp; When I entered on the road, it hardened again in a full bend at once, I barely put it aside when I stop my car and start it again, stop warning and 3 beeps sound on the display & nbsp; and the pump does not come into play, we will have to go to the industry with the savior. The problem is completely electric. Do not change the pump in vain. After a while, you can do the same again. You can press the sound of the vizzz with music. After a while, you are getting used to it. You think that there is a problem that you do not hear. Regards & nbsp;
08.05.2020 16:52 # 15
modiemlak
[QUOTE = modiemlak] steering wheel stiffening too I had it steering card burnt repaired was going to get the car today [/ QUOTE] & nbsp; & nbsp; STEERING CARD WAS BURNED AND REPAIRED ATASEHİR KOC TURNING
