The horn does not sound when the engine gets hot
08.05.2020 16:48 # 1
mrkync
Friends have peugeot 307 hdi 1.6. The horn does not work when the car's temperature reaches 90 degrees. It sounds like a click, from the horns. When the temperature drops, it starts working again. What could be the problem?
08.05.2020 16:48 # 2
In case it does not work, it can be measured whether there is current in the horn. I think there is a sase problem. You should also check the ground connection.
08.05.2020 16:48 # 3
toga406
what an interesting problem is strange.
08.05.2020 16:48 # 4
mrkync
Problem found friends. They say there is a master, there is a master. I showed it to the master, everyone kept saying brain and brain. No, there is no cost so much trouble. The solution was very simple, interesting, but the horns were broken. Horns changed, the problem is over. The cost is 60 TL. But how?
08.05.2020 16:48 # 5
omer_tarsus
You got it done cheaply again, there is a problem with me for 2 weeks. I haven't shown it to anybody yet. & nbsp;
