The high temperature hand rising when turning on the headlights
08.05.2020 16:45 # 1
zgr
hello guys my vehicle 2001 model 206xt. I did not pull anything out of the heat of this vehicle. When the vehicle runs and the temperature reaches 90 degrees, when the headlights turn on, the temperature hand exceeds 100 degrees. drops off 10 degrees when turning off the headlights. Also, when the vehicle is at 90 degrees when I stop and turn the ignition (without cranking), the temperature is up to 110 degrees. When I start, it slowly descends. Does anyone have any ideas or suggestions for this matter? thanks.
08.05.2020 16:45 # 2
toga406
Also, when the vehicle is at 90 degrees when I stop and turn the ignition (without cranking), the temperature is up to 110 degrees. slowly descends when I start
& nbsp;
this I can answer the problem. When you hit your car. If the engine fan coolant does not rotate, it means that the oil has not cooled. As soon as the ignition is switched on, the oil will be back to its former temperature. because & nbsp; the oil in the engine block has absorbed the oil.
& nbsp;
turn the ignition on when the solution is missed 20 & nbsp; keep the fan cooling for seconds or half minutes
08.05.2020 16:45 # 3
zgr
I'm trying what you said today. thank you.
08.05.2020 16:45 # 4
monur
I had the same problem, I changed the radiator and the problem was solved.
08.05.2020 16:45 # 5
toga406
Of course there is a relationship between very interesting radiator core and temperature. but interesting
08.05.2020 16:45 # 6
monur
[QUOTE = toga406] Of course there is a relationship between the very interesting radiator core and the temperature. but the interesting [/ QUOTE]
plastic part to which the hose going back to the expansion canister makes air. When it comes back to you, tighten the radiator upper hose, you will see that it will be hard like stone. Normally, this hose will have pressure, but it will never harden like a stone. Wait 1 hour before starting the vehicle. You will witness that the hose will soften again. border = "0" alt = "Wink" title = "Wink" />
08.05.2020 16:45 # 7
zgr
Guys, I guess I couldn't fully explain my problem. The headlight comes close to the pointer rises by 10 degrees, and when it extinguishes, it falls immediately to 10 degrees. the indicator does not say problematic, other & nbsp; hands do not have a problem with gasoline or tachometer. Only the temperature hand.
08.05.2020 16:45 # 8
[QUOTE = zgr] guys I guess I couldn't fully explain my problem. The headlight comes close to the pointer rises by 10 degrees, and when it extinguishes, it falls immediately to 10 degrees. the indicator does not say problematic, other & nbsp; hands do not have a problem with gasoline or tachometer. Only the temperature hand. [/ QUOTE]
Is it only in the headlights? Does it happen when it signals?
08.05.2020 16:45 # 9
zgr
not on the signal, not on the quad. The parks begin to rise up close.
08.05.2020 16:45 # 10
[QUOTE = zgr] is not on the signal, but not on the quad. parks are starting to rise up close. [/ QUOTE]
I guess there is a chassis problem somewhere. The problem is finding out from which point of origin. I think you can reach the solution with a good auto electrician.
08.05.2020 16:45 # 11
toga406
I think it's not a real situation. it's just an electrical problem like a short circuit. otherwise I don't think it will actually increase the heat
08.05.2020 16:45 # 12
zgr
[QUOTE = toga406] I think it's not a real situation. it's just an electrical problem like a short circuit. otherwise I do not think that it will actually increase the temperature [/ QUOTE]
I do not think that the temperature really rises, but when the needle comes to an end, it annoys people.
08.05.2020 16:45 # 13
zgr
My guess is that there is a chassis problem somewhere. The problem is finding out from which point of origin. I think you can reach the solution with a good auto electrician.
Is there a good electrician to understand this problem you can recommend? ist. on the european side
& nbsp;
Reviews
08.05.2020 16:45 # 14
[QUOTE = zgr]
Is there a good electrician to understand this problem that you can recommend? ist. on the european side
& nbsp;
Reviews [/ QUOTE]
I do not recommend my friends yasamadigi in Turkey but they will direct you on that idea. Reviews
08.05.2020 16:45 # 15
zgr
Reviews I do not recommend my friends yasamadigi in Turkey but they will direct you on that idea. Reviews [/ QUOTE]
Reviews
Thank you. After writing, I realized that you are in Belgium.
18.05.2023 21:36 # 16
kaan206
Were you able to find a solution?
02.08.2024 12:22 # 17
Selimben
First of all, hello to everyone, I am a new member of the forum, I have been using 206 roland garros for 2 years and I have been having an overheating problem for 2 years. 2 days ago, by chance, I noticed that the overheating indicator of the vehicle related to the headlights increased. As my friend said, when the water temperature is 90 degrees or below at night, when you turn on the headlights only, the needle suddenly goes to around 100 and when you turn it off, it drops back to 90 in 2 seconds. I called my electrician friend in Ankara and he said if the car fan is on, just stick it on and go. There is an unrelated problem somewhere. My friend who started this topic, believe me, I am more curious than you, did you solve the problem? Also, I had an extra Italian Tofaş sensor connected to the radiator. There are 2 sensors in the car now. The wrong Tofaş sensor is 87, so the fan never stops. Sometimes I have to unplug it. When I turn off the car, it runs for about 10 minutes and drops to 75-80 degrees. Here is the problem, it is ridiculous as my friend mentioned. Please, if anyone has a solution or another suggestion, please look into this again.
02.08.2024 12:31 # 18
Selimben
P.S. I noticed the same problem yesterday. I have 2 sensors connected to my car, one of which is an original Italian 87 Tofaş sensor. I noticed it by chance while coming to Marmaris for a holiday. I have been dealing with overheating problems for 2 years. The problem seems to be a very irritating situation. I turned on the headlights at night. By chance, while turning on the headlights, my eye caught the needle. I turned on the headlights because it was dark. The needle suddenly reached 100. I pulled over immediately, stopped at the side, I had turned off the headlights at that time, started the engine, everything was normal, I wanted to turn on the headlights and continue driving. I turned on the headlights and noticed the headlights again like this. Please, do you have any suggestions for a solution? I installed a Leon LED myself and connected it to the headlight fuse. Could it be from there? The left fog lamp is rotten. Could it be the chassis? In another car, when I touched the door, I used to hear a clicking sound of electricity. It hasn't been there for a long time. Please give me some advice.
02.08.2024 12:33 # 19
Selimben
02.08.2024 13:00 # 20
Selimben
