THE HIGH BEAM AND LOW BEAM PROBLEM DOES NOT EVER GO TO HIGH BEAM.
10.11.2025 11:52 # 1
tecilla
Hello friends. While returning from a long journey, I suddenly noticed that when I used the headlights, it wouldn't switch to high beam. It wouldn't even appear as a symbol on the dashboard. After a while, my low beams went out completely. However, it switched to low beam, only it wouldn't turn on. I checked all the fuses, etc., and they were all fine. I also checked the bulbs one by one. I tried it directly from the battery, and they all work fine. The taillights, brakes, everything else works. I'm only having trouble with the high beams and low beams. What do you think the problem could be? I also couldn't find the headlight relay for this vehicle. I wondered if the problem was there, but I couldn't find it.tecilla2025-11-10 11:54:46
