The heavy sound coming from ten sides
08.05.2020 19:22 # 1
Falcon
Hello friends
From the 206, which I used smoothly and fondly, while passing through the bumps recently, the sounds of squeak began to come. Since I was the first vehicle, I don't know why the problem is caused. I am waiting for your suggestions on the subject, thanks in advance. Falcon 2015-07-30 23:15:51
08.05.2020 19:22 # 2
mhrcyn
I have the same problem, just the problem with the bumps is now doing it on the flat road now.
08.05.2020 19:22 # 3
Falcon
Sir I solved it two days ago, the problem is solved. Swings bidet rot heads changed. Falcon 2015-08-01 21:04:50
08.05.2020 19:22 # 4
samet206
Certainly, they usually do the creaking from the swings. When it comes to the subject of change, you will be deformed quickly if you wear the best quality sub-industry product in your passion.
08.05.2020 19:22 # 5
Falcon
The master who changed it was also surprised whether the sound was disturbing or not :) the rods were originally replaced by the technorot brand on the swings, I hope it will not deform :)
08.05.2020 19:22 # 6
oquzhanblt
It may be from torsion .. it is slow but it doesn't come from the front, if you listen carefully, shake it, you will understand the car .. :)
08.05.2020 19:22 # 7
Falcon
Torsions are intact, the master said, the parts that I already said changed and there was no sound
08.05.2020 19:22 # 8
Falcon
[QUOTE = samet206] Definitely, they usually make the creak from the swings. When it comes to the issue of change, you will be deformed quickly if you wear the best quality sub-industry product in your passion. I do not want.
Is there any brand that you would recommend as a quality sub-industry product, Samet brother
08.05.2020 19:22 # 9
mhrcyn
[QUOTE = Falcon] Hodja, I did it two days ago, the problem is solved. Swings bidet rot heads changed. [/ QUOTE]
What did you give as a price?
08.05.2020 19:22 # 10
Falcon
390 tl kept brother (Parts 290 mastery 100 lira)
08.05.2020 19:22 # 11
samet206
[QUOTE = Falcon] [QUOTE = samet206] Absolutely creaking from swings will usually make them. When it comes to change, if you wear the best quality sub-industry product, it will be deformed quickly. I don't want to touch on the concept of changing again.
Do you have a brand that you would recommend as a quality sub-industry product Samet brother [/ QUOTE]
I do not have a chance to give a hundred percent answer, but the friend who opened the subject used the technorot swing.
08.05.2020 19:22 # 12
lthec
Hello Brother
If the sound coming from the spring bearing is the sound of the spring, it may be the shock absorber tower block. It is a 20 lira piece, but makes an uncomfortable 10,000 lira sound. even on a straight road.
