the heater is still stuffy
08.05.2020 19:32 # 1
gemlikli_55
friends, I had been using the vehicle I had been using for 2 years, I had been using it for 1 year, the master said it was clogged, I thought it was ok if it was clogged again. I changed months ago, the pie is blocked again, there is a hot water inlet, the pipe is bitter, but the honeycomb is cold from the entrance to the exit, I think it was blocked again, what should I do with friends? CryCryCry
08.05.2020 19:32 # 2
talip206
The new honeycomb should not be obstructed. Is there a problem with overheating in the vehicle. Maybe there is air in the system.
08.05.2020 19:32 # 3
gemlikli_55
There is no temperature problem, everything is normal.
I tried the bleeding event when I try to get air from the stopper on the pipe at the boiler, I get the air from the stopper when the spare water container is open, but when the spare water door mouth is closed, I do not come from the stopper I mentioned, and I could not understand an event.
08.05.2020 19:32 # 4
gemlikli_55
08.05.2020 19:32 # 5
I would recommend you take these radiator cleaners and use one. Also, the hot and cold adjusting wire behind the air conditioner control panel may be broken. or the router may be malfunctioning.
08.05.2020 19:32 # 6
gemlikli_55
The routers are solid, warm, cold, and solid because there is a cold air coming in blue. What do you recommend as a radio cleaner?
08.05.2020 19:32 # 7
teacher, there are so many products in the market. 15 TL two
08.05.2020 19:32 # 8
mimitt
The main reason for honeycomb clogging is poor quality water (mains water), the mains water is calcifying very quickly and this causes clogging of the radiator pipes after a while, there are various alternatives for cleaning process. Take pure water and top it up with antifreeze.
radiator cleaning products have been formed in the system but may cause lime leakage to occur, do not forget to check the hoses for this, make sure the tank is clean after cleaning process, drain the water several times with a quality water, run the vehicle for a few minutes while doing this keep moving. Finally, as I said, pure water or antifreeze. Let's not forget that there is a chemical in their antifreezes and that they have a lifetime, it does not provide endless protection.
08.05.2020 19:32 # 9
gemlikli_55
thank you mimitt weekend i quit _
Today, the air conditioner is not working. Why is it not working? I think it is blowing air.
