The heater does not blow hot, please help!
08.05.2020 17:09 # 1
myssteriouss
Hello everyone, we run the heating of our 305 model <6> with the cooler air. & Nbsp; Blowing but unfortunately not hot & nbsp;
We investigated a little in the industry because there is no authorized service in our location. & nbsp; they talked about different possibilities. > & nbsp;
First possibility is a blockage in the heating system. In such cases, they said that they were trying to open a porous-like liquid by opening it with pressurized water. However, if the system has a weak point, it can crack from there. It may have been a problem. & nbsp; So we are worried about getting this done. In this case, they had to remove the chest, as you can imagine, this process is a very long and troubled operation in our vehicles.
& nbsp;
Last chance is the & nbsp; heater & nbsp; honeycomb be completely corrupted. In this case, there is no solution other than removing the chest. "C
& nbsp;
Has anyone encountered such a problem between you? or if you are experiencing a similar experience, I would like your help.
08.05.2020 17:09 # 2
Serkan
The first possibility was in the cousin of our cousin, when the master bought a porce from the market and the bride said, our cousin was stunned but the problem was solved with the porcöz :)
08.05.2020 17:09 # 3
myssteriouss
Yes, they said the same, but we do not know if we had it done or not. We are afraid that if it causes more problems :(
08.05.2020 17:09 # 4
ufukozgurr
what you mentioned happened to me because too little air was left in the radiator in the old vehicle. I disassembled the radiator of the radiator and squeezed it when the water came out and relaxed when it blew the air
08.05.2020 17:09 # 5
GokhaN
I think there is a circuit that allows the boiler to deliver hot air, there is a problem with it. In my old 106, I fixed the problem by having the circuit repaired.
08.05.2020 17:09 # 6
myssteriouss
So how did they fix this circuit? did they remove the chest?
