The headlights illuminate little and .. 307 sw 2006 |
| 08.05.2020 21:02 | # 1 |
Also, the rear wipers work automatically when I touch them even when the engine is not running (even the key is not in contact). It doesn't happen very often, but it's still annoying. |
| 08.05.2020 21:02 | # 2 |
sonerkyl |
the headlights are off due to the inability of the charger to charge sufficiently. Teacher, you have a good time and you can disassemble, check and clean all the fuses. There are two options for the rear wiper to operate on its own, one may be related to possible bsi, normally our vehicles should switch to eco mode after a certain period of time and this will lead the vehicle first. Unfortunately, there is a situation like short cycle or oxidation. Has there been an excessive rain or engine washing in your car recently?
| 08.05.2020 21:02 | # 3 |
Thanks for the answer, unfortunately, I am not inclined to do these things . There was no engine washing, but it was under heavy rain. As I understand it, the auto electrician can handle both problems. It would not be bad if I went to an auto electrician in İkitelli. Thanks again. |
| 08.05.2020 21:02 | # 4 |
sonerkyl |
you are welcome hodja It would be better if you find someone who understands peugeot. In addition, there is an extra equipment in the vehicle sound system etc.
