The handbrake is frozen and I continued :(
08.05.2020 21:07 # 1
lilokan
Hello friends. I pulled the parking brake of my car with anger. And frozen in the cold. I had to travel for 2 km compulsorily. An abs lamp was lit along the road. It says abs fault on the screen. I pulled the car to the garage now. Does this lamp spontaneously end when the parking brake defrosts? Or did we get a breakdown or something?
Liloan 2018-12-30 23:18:39
08.05.2020 21:07 # 2
the reason why the rear brakes are freezing is that the parking brake wire freezes. The wire passes through a channel while using the vehicle and freezes when it parks at night as water enters this channel. I hope the sensors are not broken. I don't think there will be a problem.
08.05.2020 21:07 # 3
KILIC
I don't think there will be a problem. Do not apply the hand brake in cold weather enough to keep ice, leave the vehicle in gear, you will not have such problems.
08.05.2020 21:07 # 4
lilokan
Thank you, teacher for the answers. In the morning, while I was going, I looked at the hand brake, but the abs light continues to burn. I did not move by car. Hopefully the lamp will go out after moving a little.
08.05.2020 21:07 # 5
ismailkaya
If you check if the abs is activated, if the abs light is already on, the fault code is deleted and if it comes on again, look for a good driver.
08.05.2020 21:07 # 6
lilokan
Sir, sorry, the answer was a little late. I moved only 20 meters with the car and the lamp went out. Abs works smoothly.
